what other parts do I need, 2.0 conversion |
tat2dphreak |
Feb 11 2004, 03:36 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
once I get a 2.0 L engine to replace my 1.7(or 1.8) what else do I need? what parts interchange?
Heat exchangers? mufflers? muffler hanger? distributor? carb manifold? (I know I will have to drill a hole for the 3-bolt attachment) what am I forgetting that I need to consider? (IMG:style_emoticons/default/idea.gif) can you tell I'm excited about what the car will run like with an engine that has good compression?! (IMG:style_emoticons/default/driving.gif) |
Dave_Darling |
Feb 11 2004, 05:27 PM
The 1.7 exchangers (also used on 74 1.8) work fine on a 2.0 engine. They have a bit more bending and are smaller in diameter, which gives you slightly worse flow than the 2.0 parts. But they still work fine.
You must use a muffler and muffler hanger and exchangers of the same type as each other. No mixing and matching; they don't fit correctly. But you can swap the setup between motors as a complete package. --DD |
Lo-Fi Version | Time is now: 7th June 2024 - 07:47 AM |
