> Is this 911 engine any good for a 914 swap?, Engine number inside..
Rod
post Aug 26 2009, 04:49 PM
Region Association: England
I can get my hands on this engine very reasonably would it be a good choice for a 914 swap or would a 3.0 or a 3.2 be a better bet?
Engine number 6151404 1975 2.7 with cis
Cupomeat
post Aug 27 2009, 04:04 PM
missing my NY 914 in VA
I agree with Mike, in that if you are shopping for a new motor, go with the 3.0 (SC motor) or the 3.2 (carrera) motor.
The 2.7 motors are the most fragile in un-updated form and unless the motor was free will likely cost you more than the 3.0 or 3.2.
Of course, the years do matter with the 2.7 as the later 2.7's were installed with thermal reactors which pretty much killed them (heat) and they were often taken out and replaced with the newer motors. Also, the head studs are notorious for pulling out and the original fix by Porsche for this problem is failure prone as well.
SO, that is probably why we see more of them than any other series for sale.
NOW, I am no 911 engine guru, but this story about the 2.7 has been told ever since I was a kid and most everyone who has one that I know agrees, or has already been through this.
I hope this helped.
Rod
post Aug 27 2009, 04:20 PM
QUOTE(Cupomeat @ Aug 27 2009, 11:04 PM) *
I hope this helped.
Helps a lot (IMG:style_emoticons/default/smile.gif) Enough to keep my wallet in my back pocket and hunt for that 3.2 Carrera I was looking for in the first place....
(IMG:style_emoticons/default/driving-girl.gif)
Rod   Is this 911 engine any good for a 914 swap?   Aug 26 2009, 04:49 PM
thesey914   Rod, sounds like the 150hp/235lbs/ft version. Has ...   Aug 26 2009, 06:06 PM
SLITS   A decent 2.7L will give you wood!   Aug 26 2009, 07:34 PM
lotus_65   i would like it... :)   Aug 26 2009, 07:58 PM
Vacca Rabite   What shape is the motor in? Has it had all the 2.7...   Aug 26 2009, 08:47 PM
pete-stevers   not to discourage a six build but why did theat 2....   Aug 26 2009, 09:16 PM
Mike Gilbert   in the long run you will be better off with the 3....   Aug 27 2009, 03:51 PM
Cupomeat   I agree with Mike, in that if you are shopping for...   Aug 27 2009, 04:04 PM
Rod   I hope this helped. Helps a lot :) Enough to ke...   Aug 27 2009, 04:20 PM
J P Stein   There are a lot of opinions here but apparently no...   Aug 27 2009, 06:05 PM
ArtechnikA   I know bout 2.7s. This one *may* be F/S in a coup...   Aug 27 2009, 07:59 PM
J P Stein   I know bout 2.7s. This one *may* be F/S in a cou...   Aug 27 2009, 08:04 PM
ArtechnikA   Be advised, it uses race gas.......but it's a...   Aug 27 2009, 08:10 PM
J P Stein   Be advised, it uses race gas.......but it's ...   Aug 27 2009, 08:26 PM
ArtechnikA   A good twin plug set-up is pricy. yes, but I...   Aug 28 2009, 06:35 AM
J P Stein   A good twin plug set-up is pricy. yes, but I...   Aug 28 2009, 01:45 PM
BKLA   I'm with JP on this... a 2.7 can be quite a ni...   Aug 27 2009, 08:05 PM
J P Stein   I'm with JP on this... a 2.7 can be quite a n...   Aug 27 2009, 08:09 PM
sixnotfour   JP that distributor I sold you is for sale on 911...   Aug 27 2009, 09:22 PM
J P Stein   Yeah, I should'a bought 100 of em'...........   Aug 27 2009, 09:45 PM
degreeoff   I like mine.....I am redoing a bad mistake now tha...   Aug 27 2009, 09:51 PM
Vacca Rabite   Itwas a sick (as in poor running) engine in my te...   Aug 28 2009, 10:46 AM
GeorgeRud   A properly prepared 2.7 is a hoot, and a lot of fu...   Aug 27 2009, 10:44 PM
GreatPumpkin   NO, Dont listen to these guys... That will never...   Aug 28 2009, 11:24 AM
Cupomeat   J P Stein, thanks for fixing my mistake as I did n...   Aug 28 2009, 02:08 PM
pete-stevers   alas...the 2.7 guys seem to have dominated....yup ...   Aug 28 2009, 03:14 PM
SirAndy   alas...the 2.7 guys seem to have dominated....yup...   Aug 28 2009, 04:02 PM
ArtechnikA   alas...the 2.7 guys seem to have dominated....yup...   Aug 28 2009, 06:32 PM
Ferg   When I had my six, I took the 2.7 out and put in a...   Aug 28 2009, 04:12 PM
SLITS   How can you say that Ferg ... you don't keep a...   Aug 28 2009, 04:48 PM
SirAndy   How can you say that Ferg ... you don't keep ...   Aug 28 2009, 05:07 PM
J P Stein   The 3.0L 9eleben engine is the most reliable engin...   Aug 28 2009, 06:58 PM
pete-stevers   jeez....i didn't think any one ever noticed th...   Aug 31 2009, 10:29 PM
- Lo-Fi Version Time is now: 6th October 2026 - 04:14 PM
