> Is this 911 engine any good for a 914 swap?, Engine number inside..
Rod
post Aug 26 2009, 04:49 PM
Region Association: England
I can get my hands on this engine very reasonably would it be a good choice for a 914 swap or would a 3.0 or a 3.2 be a better bet?
Engine number 6151404 1975 2.7 with cis
J P Stein
post Aug 27 2009, 06:05 PM
Irrelevant old fart
There are a lot of opinions here but apparently not much actual experience....with a few exceptions. I know a fella that has well over 200K miles on his (never opened) 2.7L and he flogs the thing regularly.
With any used motor one could ask "why was the engine removed....".
One could spend $10K..."just on parts" but I have no idea how.
No thermal reactors in the UK in 75', eh?
Ah well, this is the internet.....
All the 911 engines can have back holes just waiting to be filled with your dollars (pounds). All were good at one point in their lives. Pitfalls abound in any used motor. All are core motors unless you can see and hear them run. All are not equally expensive to rebuild.....but BS is free. The 2.7L is one of the least expensive due to parts availability (both new & used).
I know bout 2.7s. This one *may* be F/S in a couple weeks.
ArtechnikA
post Aug 27 2009, 07:59 PM
rich herzog
QUOTE(J P Stein @ Aug 27 2009, 08:05 PM) *
i _may_ be interested. keep me posted...
J P Stein
post Aug 27 2009, 08:04 PM
Irrelevant old fart
QUOTE(ArtechnikA @ Aug 27 2009, 06:59 PM) *
Be advised, it uses race gas.......but it's a hoot & smells gud. (IMG:style_emoticons/default/biggrin.gif)
ArtechnikA
post Aug 27 2009, 08:10 PM
rich herzog
QUOTE(J P Stein @ Aug 27 2009, 10:04 PM) *
can't see the dizzy but there's only one coil so I'm guessing it's still single ignition. Another set of plugs could put it in the 93-octane pump gas region for light use, i'm thinking...
Rod   Is this 911 engine any good for a 914 swap?   Aug 26 2009, 04:49 PM
thesey914   Rod, sounds like the 150hp/235lbs/ft version. Has ...   Aug 26 2009, 06:06 PM
SLITS   A decent 2.7L will give you wood!   Aug 26 2009, 07:34 PM
lotus_65   i would like it... :)   Aug 26 2009, 07:58 PM
Vacca Rabite   What shape is the motor in? Has it had all the 2.7...   Aug 26 2009, 08:47 PM
pete-stevers   not to discourage a six build but why did theat 2....   Aug 26 2009, 09:16 PM
Mike Gilbert   in the long run you will be better off with the 3....   Aug 27 2009, 03:51 PM
Cupomeat   I agree with Mike, in that if you are shopping for...   Aug 27 2009, 04:04 PM
Rod   I hope this helped. Helps a lot :) Enough to ke...   Aug 27 2009, 04:20 PM
J P Stein   There are a lot of opinions here but apparently no...   Aug 27 2009, 06:05 PM
ArtechnikA   I know bout 2.7s. This one *may* be F/S in a coup...   Aug 27 2009, 07:59 PM
J P Stein   I know bout 2.7s. This one *may* be F/S in a cou...   Aug 27 2009, 08:04 PM
ArtechnikA   Be advised, it uses race gas.......but it's a...   Aug 27 2009, 08:10 PM
J P Stein   Be advised, it uses race gas.......but it's ...   Aug 27 2009, 08:26 PM
ArtechnikA   A good twin plug set-up is pricy. yes, but I...   Aug 28 2009, 06:35 AM
J P Stein   A good twin plug set-up is pricy. yes, but I...   Aug 28 2009, 01:45 PM
BKLA   I'm with JP on this... a 2.7 can be quite a ni...   Aug 27 2009, 08:05 PM
J P Stein   I'm with JP on this... a 2.7 can be quite a n...   Aug 27 2009, 08:09 PM
sixnotfour   JP that distributor I sold you is for sale on 911...   Aug 27 2009, 09:22 PM
J P Stein   Yeah, I should'a bought 100 of em'...........   Aug 27 2009, 09:45 PM
degreeoff   I like mine.....I am redoing a bad mistake now tha...   Aug 27 2009, 09:51 PM
Vacca Rabite   Itwas a sick (as in poor running) engine in my te...   Aug 28 2009, 10:46 AM
GeorgeRud   A properly prepared 2.7 is a hoot, and a lot of fu...   Aug 27 2009, 10:44 PM
GreatPumpkin   NO, Dont listen to these guys... That will never...   Aug 28 2009, 11:24 AM
Cupomeat   J P Stein, thanks for fixing my mistake as I did n...   Aug 28 2009, 02:08 PM
pete-stevers   alas...the 2.7 guys seem to have dominated....yup ...   Aug 28 2009, 03:14 PM
SirAndy   alas...the 2.7 guys seem to have dominated....yup...   Aug 28 2009, 04:02 PM
ArtechnikA   alas...the 2.7 guys seem to have dominated....yup...   Aug 28 2009, 06:32 PM
Ferg   When I had my six, I took the 2.7 out and put in a...   Aug 28 2009, 04:12 PM
SLITS   How can you say that Ferg ... you don't keep a...   Aug 28 2009, 04:48 PM
SirAndy   How can you say that Ferg ... you don't keep ...   Aug 28 2009, 05:07 PM
J P Stein   The 3.0L 9eleben engine is the most reliable engin...   Aug 28 2009, 06:58 PM
pete-stevers   jeez....i didn't think any one ever noticed th...   Aug 31 2009, 10:29 PM
- Lo-Fi Version Time is now: 6th October 2026 - 04:14 PM
