> Still no turn signals
silverteener
post Aug 22 2009, 02:12 PM
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now!
silverteener
post Aug 28 2009, 06:06 PM
I didn't get any volts from either side on #9. I did on 10 just to make sure I was doing it right. I checked with the key off and the 4 way pulled out.
silverteener   Still no turn signals   Aug 22 2009, 02:12 PM
type47   Only suggestions I can make are to find places in ...   Aug 22 2009, 03:16 PM
orange914   get a diagram and trace power from the fuse up, wi...   Aug 22 2009, 03:16 PM
silverteener   trying to work on this again. I had an exta fuse ...   Aug 27 2009, 07:49 PM
904svo   Let me know the results of this test, with key off...   Aug 27 2009, 09:37 PM
silverteener   came home for lunch so I could try it but I don...   Aug 28 2009, 11:50 AM
904svo   came home for lunch so I could try it but I don...   Aug 28 2009, 03:47 PM
Garold Shaffer   I'm at a lose and there is no one around her...   Aug 28 2009, 02:46 PM
silverteener   I didn't get any volts from either side on #9....   Aug 28 2009, 06:06 PM
904svo   I didn't get any volts from either side on #9...   Aug 28 2009, 06:40 PM
silverteener   on the top I got 12v but the bottom was sparking a...   Aug 28 2009, 08:12 PM
904svo   on the top I got 12v but the bottom was sparking ...   Aug 28 2009, 08:36 PM
silverteener   I took all the bulbs out and put a new fuse in and...   Aug 29 2009, 07:55 AM
904svo   You have a short in the circuit, goto to your auto...   Aug 29 2009, 08:32 AM
silverteener   I have a 3157 bulb but i'm confused on how to ...   Aug 29 2009, 12:44 PM
silverteener   I forgot you said it runs the interior light. I w...   Aug 29 2009, 12:47 PM
silverteener   Where does the interior light ground. I traced th...   Aug 29 2009, 01:05 PM
jt914-6   According to my diagram, the interior light ground...   Aug 29 2009, 01:27 PM
orange914   i eally dont understand it but i've seen weak ...   Aug 29 2009, 01:36 PM
silverteener   I cleaned that ground up and put the interior bulb...   Aug 29 2009, 01:51 PM
904svo   I cleaned that ground up and put the interior bul...   Aug 29 2009, 04:58 PM
ws91420   Shouldn't the turn signals be a 1156 single po...   Aug 29 2009, 02:19 PM
orange914   Shouldn't the turn signals be a 1156 single p...   Aug 29 2009, 03:51 PM
tod914   Try reseating all the connectors into the signal h...   Aug 29 2009, 05:07 PM
904svo   Try this if you can find the flasher relay check f...   Aug 29 2009, 09:43 PM
silverteener   Ok, I went and got 2 1156's for the front. ...   Aug 29 2009, 10:00 PM
904svo   Sounds like you have a bad relay, check this first...   Aug 29 2009, 10:22 PM
silverteener   with the key off and the left turn signal on my le...   Aug 29 2009, 10:35 PM
904svo   with the key off and the left turn signal on my l...   Aug 29 2009, 11:10 PM
silverteener   I'll have to order one. :( I think Pelican h...   Aug 29 2009, 11:21 PM
904svo   I'll have to order one. :( I think Pelican ...   Aug 30 2009, 09:47 AM
silverteener   I think I found one at O'Reillys. This one is...   Aug 31 2009, 06:15 PM
904svo   I think I found one at O'Reillys. This one i...   Aug 31 2009, 07:50 PM
silverteener   The new relay didn't work. I still have somet...   Aug 31 2009, 10:19 PM
drive-ability   The new relay didn't work. I still have some...   Sep 1 2009, 11:19 PM
jt914-6   That is "normal". It should do that. Tha...   Sep 1 2009, 05:55 AM
904svo   With the key off left turn signal on, Both front a...   Sep 1 2009, 10:55 AM
silverteener   who knows, I'm going to look at it more tonig...   Sep 2 2009, 11:59 AM
drive-ability   who knows, I'm going to look at it more toni...   Sep 2 2009, 12:40 PM
blazerchad   been dealing with turn signals on my 72 1.7.. fla...   Sep 6 2009, 12:59 PM
Rod   been dealing with turn signals on my 72 1.7.. fl...   Sep 6 2009, 01:10 PM
blazerchad   until I got a brand new OE relay, since then it h...   Sep 6 2009, 01:24 PM
Rod   until I got a brand new OE relay, since then it ...   Sep 6 2009, 01:31 PM
gothspeed   The new relay didn't work. I still have some...   Sep 16 2009, 04:19 PM
904svo   Do the 4 way flashers work? If not, check you have...   Sep 16 2009, 05:20 PM
silverteener   The 4 ways don't work. I do have 12v at the re...   Sep 16 2009, 09:31 PM
904svo   The 4 ways don't work. I do have 12v at the r...   Sep 16 2009, 09:56 PM
silverteener   let me try measuring the relay instead of the swit...   Sep 16 2009, 10:19 PM
silverteener   I checked on the relay and on 49 I have 12v and on...   Sep 16 2009, 10:37 PM
904svo   I checked on the relay and on 49 I have 12v and o...   Sep 17 2009, 07:56 AM
silverteener   So I get my new relay from Pelican today, not real...   Sep 18 2009, 09:30 PM
904svo   So I get my new relay from Pelican today, not rea...   Sep 18 2009, 09:40 PM
silverteener   I did what you said and the fuse only blew when I ...   Sep 19 2009, 02:03 PM
silverteener   doesn't that red wire run up to the relay? I...   Sep 19 2009, 02:19 PM
silverteener   I cut off the rubber grommet from the relay and al...   Sep 19 2009, 04:17 PM
904svo   Here's the brake down on the wires to the flas...   Sep 19 2009, 06:41 PM
Spoke   It's a real bummer that this issue has been pl...   Sep 19 2009, 10:42 PM
Spoke   Same circuit as previous post except circuit eleme...   Sep 20 2009, 08:07 AM
gothspeed   Do the 4 way flashers work? If not, check you hav...   Sep 21 2009, 03:13 PM
904svo   Do the 4 way flashers work? If not, check you ha...   Sep 21 2009, 04:32 PM
silverteener   I'm still working in the tests. I got to #3, ...   Sep 21 2009, 10:05 PM
Spoke   Did you pull the red wire off of the flasher relay...   Sep 22 2009, 11:30 AM
silverteener   It's working!! :Qarl: :Qarl: Thanks...   Sep 23 2009, 04:36 PM
76-914   :agree: Man, you got some top notch help. How ...   Sep 23 2009, 08:43 PM
- Lo-Fi Version Time is now: 8th July 2025 - 09:18 PM
