> any tips for tuning weber 34ict?
JOE M
post Aug 28 2009, 03:49 PM
Curious about how to set the carbs up.The timing is close but may be out slightly.I started by turning the air mixture screws all the way in and than backing both off by 2 1/2 turns to start. I let the car idle and than I move 1 side until the car runs rough than back off the other way about 1/2 turn.I did the same for the other side. It runs ok but pops through the exhaust every now and than.It gets better when I take the throtle linkage off.I think my biggest problem is seting the idle speed screw. Is there something I should do prior to starting any other alignment?I read the procedure but I am stumped. What typically causes it to pop through the exhaust?I did check the vacum on both sides and they are real close ( within 1 of each other).
McMark
post Aug 28 2009, 06:43 PM
914 Freak!
symmetrical (cross bar type linkage) you want your drop links to be as close to straight up and down as possible as well as even between the left and right side. If one is at a severe angle compared to the other, you will have problems because one carb will always lag or lead the other later.
I think this is a slightly improper description, which I've seen reiterated many times. The symmetry of the linkage is irrelevant as long as the butterflies are both closed completely at idle and hit WOT at the same time. I fear that emphasizing the symmetry leads people to focus too much on the looks of the linkage and takes away what they should be focusing on, the actual operation.
I've heard of people pulling out tape measures to equalize their linkage. Which is the WRONG approach. I've synched a linkage that was certainly NOT symmetrical, but hit idle and WOT perfectly.
I'm not trying to attack you, Nate. Just a general perspective of mine.
---Joe,
You should get some air flow from the crankcase breather. You would be best served by investing in an actual breather box. What you might be noticing is that as the oil vapor coalesces in the cone filter you've got, it starts to get blown out into the engine bay as vapor. Your setup will absolutely cover the engine in a ugly, oily spray within a few hundred miles.
Is the motor new or old? 1.7?
JOE M
post Aug 28 2009, 06:52 PM
QUOTE(McMark @ Aug 28 2009, 05:43 PM) *
---Joe,
Its an old 1.7 that had no compression on a couple cylinders when I got it. I agree that it is more vapor than actual smoke. Deffinently vapor from the oil cap.What causes this to happen and should I be concerned. Like I said it did not happen until I adjusted the valves and timing.Also all of my hardare for the exhaust is tight? Im not sure where I could be getting a leak? It`s a little pop and sometimes mostly has a low ressanance sort of base like a drum.
Where do I get a breather box? Sorry for all the questions at once.
JOE M   any tips for tuning weber 34ict?   Aug 28 2009, 03:49 PM
JOE M   By the way it seems to smoke through the breather....   Aug 28 2009, 03:52 PM
neil30076   By the way it seems to smoke through the breather...   Aug 28 2009, 04:20 PM
jmill   What typically causes it to pop through the exhau...   Aug 28 2009, 04:03 PM
McMark   Make sure to sync the airflow for the left/right c...   Aug 28 2009, 05:01 PM
JOE M   Make sure to sync the airflow for the left/right ...   Aug 28 2009, 06:25 PM
aircooledtechguy   Here's how I sync duals. . . First ensure al...   Aug 28 2009, 05:38 PM
McMark   I think this is a slightly improper description,...   Aug 28 2009, 06:43 PM
JOE M   I think this is a slightly improper description...   Aug 28 2009, 06:52 PM
aircooledtechguy   I think this is a slightly improper description, ...   Aug 29 2009, 10:14 AM
JOE M   [quote name='McMark' post='1208515' date='Aug 28 ...   Aug 29 2009, 10:31 AM
904svo   Try this. Just had a crazy problem an this fix ...   Aug 28 2009, 07:11 PM
JOE M   Try this. Just had a crazy problem an this fix...   Aug 28 2009, 07:46 PM
904svo   Try this. Just had a crazy problem an this fi...   Aug 28 2009, 11:18 PM
JOE M   [quote name='JOE M' post='1208536' date='Aug 28 2...   Aug 29 2009, 08:24 AM
904svo   [quote name='JOE M' post='1208536' date='Aug 28 ...   Aug 29 2009, 08:35 AM
McMark   Jake Raby sells a breather box. Chris Foley sells ...   Aug 28 2009, 07:32 PM
McMark   The exhaust can seem tight and still have a leak. ...   Aug 28 2009, 07:38 PM
McMark   The port with thr red cap should NOT be used for v...   Aug 28 2009, 09:40 PM
r_towle   if you exhaust is leaking, get a small 2*4 and hol...   Aug 28 2009, 10:53 PM
JOE M   Easy enough--how about for the vacum advance. Shou...   Aug 29 2009, 08:44 AM
McMark   Yup. VW did it with their dual single throat Sole...   Aug 29 2009, 11:11 AM
McMark   Oh, just remember to pull the balance tube and plu...   Aug 29 2009, 11:27 AM
hi4head   I installed a set of the Weber 34 ICT's last y...   Aug 30 2009, 08:48 PM
JOE M   I installed a set of the Weber 34 ICT's last ...   Aug 31 2009, 11:12 AM
McMark   You don't want to T your vacuum lines to atmos...   Aug 31 2009, 01:38 PM
r_towle   Two type of vacuum ports bud. the manifold vacuum ...   Aug 31 2009, 05:02 PM
hi4head   Joe, Rich is right on with his comments. If it he...   Sep 1 2009, 07:39 PM
jcd914   Finally, I have a short length of hose connected ...   Sep 2 2009, 01:43 PM
JOE M   Thanks for all your help. I installed all the conn...   Sep 2 2009, 05:02 AM
r_towle   Flip the carbs side for side and flip the linkage ...   Sep 2 2009, 06:59 AM
JOE M   Flip the carbs side for side and flip the linkage...   Sep 2 2009, 11:08 AM
r_towle   You can get what you have to work fine...really. I...   Sep 2 2009, 12:33 PM
hi4head   Joe, Sorry if this is hijacking your thread a litt...   Sep 3 2009, 06:55 PM
JOE M   Joe, Sorry if this is hijacking your thread a lit...   Sep 4 2009, 07:21 AM
- Lo-Fi Version Time is now: 28th September 2026 - 08:37 PM
