silverteener |
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 ![]() |
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now! |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,126 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
You have a short in the circuit, goto to your auto store a buy a 3157 lamp.
You then twist the leads coming out of the bulb. Use clip leads to connect these leads to the # 11 fuse the bulb will be use as a indicator to find your short. The bulb will glow if there is a short by checking your connections you should be able to find the short. Fuse #11 powers the interior light,4 ways and buzzer circuit (if equipped) and the clock if you have the console. I would check the interior light light circuit first as this wiring get shorted from the seats. When you clear the short the bulb should go out. Hope you find your short. |
Lo-Fi Version | Time is now: 8th July 2025 - 09:44 PM |
