silverteener |
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 ![]() |
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now! |
silverteener |
I have a 3157 bulb but i'm confused on how to run the test. do I hook up the bulb to to panel with the fuse in #11.
"The bulb will glow if there is a short by checking your connections you should be able to find the short". I'm not sure exactly how to do this either. I did take all the bulbs out again, with them all out and a good fuse in, once I pull the hazard switch the fuse blows. |
Lo-Fi Version | Time is now: 8th July 2025 - 09:27 PM |
