silverteener |
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 ![]() |
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now! |
904svo |
904SVO ![]() ![]() ![]() Group: Members Posts: 1,126 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 ![]() |
Try this if you can find the flasher relay check for the following pin#31 should be
grounded,pin#49 should have +12 volts on it when the 4way is pull out. I will guess that pin #31 has a bad ground wire on it, that ground is located under the dash by the fuse panel. Pin31 has a red wire on it, pin49 has a brown wire on it. Terminal #49 on 4way switch has the Red wire going to the flasher, terminal #30 on switch gets it power from fuse#11. |
Lo-Fi Version | Time is now: 8th July 2025 - 09:40 PM |
