Shoulder harness mount rules, Looking for help regarding installation of 5 pt harnesses in a 914 tra |
Cupomeat |
Aug 19 2009, 10:13 AM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Does anyone know the rules reagrding shoulder harness termination for DE?
We are building a 914 track car and it has a cage (CFR weld in) in it, that ties into the firewall behind the seats in three places across the firewall. Can we terminate the shoulder harnesses at the roll cage, or does it need to be terminated at the firewall and looped over (through steel keeper loops)the cage horizontal bar at the firewall? Any assistance would be helpful! Thanks |
Cupomeat |
Aug 19 2009, 01:06 PM
Thanks Again,
Yes, we intend to add the steel loops to the Cage cross bar, and yes, it has been painted, but that is the easy stuff! Now, to figure out how to mount the seats to get enough flexibility in height for both drivers to fit (5" height delta). |
SirAndy |
Aug 19 2009, 01:36 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Now, to figure out how to mount the seats to get enough flexibility in height for both drivers to fit (5" height delta). Custom aluminum sidepanels with a row of mounting holes work OK. You'd still have to undo 4 bolts move the seat up and bolt it back on, but it'll give you 5" to work with. If one of you is over about 6'1", consider removing the cross brace on the floor and mounting the sidepanels directly to the floor. That'll give you another 2" of headroom for the larger driver. (IMG:style_emoticons/default/driving.gif) Andy |
roadster fan |
Aug 31 2009, 05:40 AM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
consider removing the cross brace on the floor and mounting the sidepanels directly to the floor. That'll give you another 2" of headroom for the larger driver. Hey Andy, Do you have to replace the cross brace with something else? Move it forward? I have thought about this as a way to lower the seat but am concerned about changing the chassis strength. I will be putting in a Engman long kit but interested in real world results from someone who has done it or seen it done. Jim |
Lo-Fi Version | Time is now: 10th June 2024 - 11:12 AM |
