> 2.7 CIS mouting studs, also: one frozen stud
Scott S
post Aug 31 2009, 11:01 AM
Small Member
Hi All -
I am continuing to strip down the new motor. I still can get over how clean it is (even under the fan shroud). Other than a small crank case breather leak, all appears to be tight.
I have removed all of the CIS, including the throttle bracket plate. This was attached to the block on studs that go into the case and then through holes in the fan shroud. Being that I am going to carbs, can I remove these studs?
Also, I know I need longer intake studs when going to carbs. I was able to remove the existing ones pretty easily - except for one (of course). I have soaked the thing in pentrating oil for days - but it is still tight as can be. Should I heat it up with a torch? Our local Tool King has a cool looking stud puller that goes over the entire stud and uses a breaker bar - are these any good? I am just using the double-nut technique now....
Thanks!!!!!!
Scott S
SLITS
post Aug 31 2009, 11:05 AM
"This Utah shit is HARSH!"
The stud remover will either break the stud or pull it .... yeh, I have one and they work.
After soaking in PB Blaster again, I would heat the stud red and then let it cool. Smack it with a hammer and then try again to pull it.
Yes, I have had to drill them out ...
Good luck.
- Lo-Fi Version Time is now: 8th December 2025 - 10:42 PM
