| FourBlades |
Aug 31 2009, 03:40 PM
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States
I would like to disable the seating and seat belt warning system in my 73. I have
aftermarket seats and belts and don't want to deal with this system. So can I tie certain wires to ground or to each other to make the 914 brain happy? I can post pictures of the wires when I get home. Don't want to cut up my wiring harness too much. Thanks, John |
| r_towle |
Aug 31 2009, 04:55 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
To disable the buzzer you need to go under the passenger seat, unplug the silver box (looks like a relay, but its not a relay) and that disables everything.
It also disables the starter circuit so you need to (as said above) jumper the two large yellow wires together. The easiest way to do this is to make a 1.5 inch thick wire with two male spades on it and plug it into the appropriate slots on the brown block that you pulled the silver thing out of... Rich |
FourBlades Disabling the seating and belt warnings. Aug 31 2009, 03:40 PM
ConeDodger
I would like to disable the seating and seat belt... Aug 31 2009, 03:53 PM
ConeDodger That is it. Put a jumper between the two yellows. ... Aug 31 2009, 04:14 PM
Jeff Bowlsby Naw..this is the easy way and I understand the dea... Sep 2 2009, 06:46 PM
kconway Hope this is still on topic, don't mean to hij... Aug 31 2009, 04:59 PM
jt914-6 Rich....I don't think that the system you desc... Aug 31 2009, 05:06 PM
FourBlades OK, so I searched some more using +seat +warn titl... Aug 31 2009, 08:30 PM
jt914-6 John....Do you have a relay looking box under the ... Aug 31 2009, 09:02 PM
FourBlades Um, my car had a large rusty hole under each of th... Sep 1 2009, 06:16 AM
jt914-6 I'm sure a '73 didn't have the seat be... Sep 1 2009, 06:24 AM
zx-niner Here's what my '74 looks like where I remo... Sep 2 2009, 08:01 PM
jt914-6
Here's what my '74 looks like where I rem... Sep 2 2009, 08:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 01:43 PM |
