> Interior Water Leaks(wet carpet specifically), Where might it be coming from?
casey944
post Aug 31 2009, 06:11 PM
So, I replaced the carpet in my car a month or 2 ago and we have had some steady rain since. Felt my carpet today as I was working in my car and felt that both the driver and pass sides are wet. Not the hump in between, not the seats, not the door panels... just the carpet in the foot wells. Where would you recommend I begin searching for leaks? I bought a superweave cover from Cal Car Covers today in hopes that it will cure 98% of the issue but this still bothers me... any help?
Thanks.
SLITS
post Aug 31 2009, 06:20 PM
"This Utah shit is HARSH!"
Window seals .............
MDG
post Aug 31 2009, 07:01 PM
Wolf in wolf's clothing.
QUOTE(SLITS @ Aug 31 2009, 08:20 PM) *
what he said.
make sure you check the seal around the rear window too; the water runs down behind the backpad and oozes throughout the carpet.
casey944   Interior Water Leaks(wet carpet specifically)   Aug 31 2009, 06:11 PM
SLITS   Window seals .............   Aug 31 2009, 06:20 PM
MDG   Window seals ............. what he said. make ...   Aug 31 2009, 07:01 PM
gtp914   Window seals ............. what he said. make...   Sep 2 2009, 03:38 PM
MDG   [quote name='MDG' post='1209491' date='Aug 31 200...   Sep 2 2009, 04:06 PM
casey944   Are you referring to teh seals that go on either s...   Aug 31 2009, 07:00 PM
9146986   You need this!   Aug 31 2009, 07:19 PM
casey944   You need this! I am goign to get one of...   Sep 1 2009, 11:44 AM
Cupomeat   Might be window seals, but you should see the wate...   Aug 31 2009, 09:00 PM
casey944   Also could be a plugged up drain in the fresh air...   Sep 1 2009, 11:43 AM
SLITS   Also could be a plugged up drain in the fresh ai...   Sep 1 2009, 11:55 AM
MDG   Might be window seals, but you should see the wat...   Sep 1 2009, 02:46 PM
gtp914   Might be window seals, but you should see the wa...   Sep 2 2009, 03:34 PM
1970 Neun vierzehn   Is your floor pan solid? You don't want to see...   Aug 31 2009, 09:07 PM
balljoint   Do you have a V8 or other high HP power-plant?   Sep 1 2009, 12:00 PM
McMark   Once upon a time, I also fixed this same 'myst...   Sep 1 2009, 12:18 PM
underthetire   The question should be where does a 914 not leak a...   Sep 1 2009, 01:45 PM
jaxdream   Wiper seals might do this , but most of these comp...   Sep 1 2009, 01:58 PM
Drums66   [quote name='casey944' Where would you re...   Sep 1 2009, 05:43 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:34 PM
