| montoya 73 2.0 |
Aug 16 2009, 12:37 AM
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I know the steps:
- take off 4 bolts tranny to engine - unhook 2 tranny mounts in the back - take off 2 axels - take off shift linkage - remove muffler/muffler hanger - remove starter and wire to reverse switch - remove speedo cable - remove clutch cable - disconnect tranny ground strap (EDIT: Not necessarliy in correct order) But whats the best way to remove without damaging: Shift linkage (remove the Spam Can without damaging the clamp), speedo cable & clutch cable? A few pictures of what I'm dealing with... ![]() "Spam Can" ![]() Attached image(s)
| Dr Evil |
Sep 2 2009, 12:18 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Sure, with enough money you can do anything. 2nd is not changeable unless you have an $1800+ 904 input shaft and the associated gears (IMG:style_emoticons/default/wink.gif)
montoya 73 2.0 Removing Transmission, Need advice and help... Aug 16 2009, 12:37 AM
Mark Henry Big nut on speedo drive, do it carefully and don... Aug 16 2009, 01:04 AM
Dr Evil 4 bolts tranny to engine are LAST, unless you want... Aug 16 2009, 01:31 AM
montoya 73 2.0 Thank you! Aug 16 2009, 11:54 AM
Bristol I just did this job last week (bad seal on trans s... Aug 17 2009, 11:32 AM
montoya 73 2.0 Where and what exactly do I remove? Aug 17 2009, 02:15 PM
Cupomeat Ok, at the end of the shift rod, behind the bushin... Aug 17 2009, 02:20 PM
montoya 73 2.0
Ok, at the end of the shift rod, behind the bushi... Aug 17 2009, 02:57 PM
Dr Evil The yellow arrow is the rear conical screw. There ... Aug 17 2009, 06:30 PM
montoya 73 2.0
The yellow arrow is the rear conical screw. There... Aug 17 2009, 11:04 PM
Dr Evil PM and remind me. I will be making some this week ... Aug 17 2009, 11:12 PM
montoya 73 2.0 I believe this sending unit has to be removed but ... Aug 23 2009, 04:44 PM
Dave_Darling Just unplug it; the wires have bullet-shaped conne... Aug 23 2009, 04:55 PM
montoya 73 2.0
Just unplug it; the wires have bullet-shaped conn... Aug 23 2009, 04:56 PM
montoya 73 2.0 Pulled out the Tranny the next day (Monday). But t... Sep 1 2009, 11:11 PM
Dr Evil Oh Shit! That is totally OK. Sep 1 2009, 11:31 PM
montoya 73 2.0 Okay cool! Just checking.
Quick question, Is ... Sep 1 2009, 11:55 PM
montoya 73 2.0
Sure, with enough money you can do anything. 2nd ... Sep 2 2009, 04:49 PM
jimkelly rpm's high - you want to drive in the gear tha... Sep 2 2009, 09:51 AM
montoya 73 2.0 Wasn't thinking that far in advance, But i gue... Sep 2 2009, 04:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 11:20 AM |
