> How bad is it Doc?, Rust control
Dman
post Apr 2 2003, 12:29 PM
Give it to me straight guys how bad is this? (IMG:style_emoticons/default/unsure.gif)
Should I replace all of the panels or is there an alternatve? There is a small 3/8 hole in the top of the frame member but there is NO rust on the bottom side of the car (jack point/suspension mount).
airsix
post Apr 2 2003, 01:26 PM
I have bees in my epiglotis
QUOTE(Dman @ Apr 2 2003, 10:29 AM)
Give it to me straight guys how bad is this?  :unsure:
Dman,
If you can weld or have a friend who can this is no big deal. Looks like you've got the engine out, so you're well on your way. I'll contradict Andy just a little and say grind out the bad stuff. It's the only way to know for sure how far the damage goes. You may find that 3/8" hole will open up to 6"x4" before you get to solid metal. Trim your holes up nice with an angle grinder or whatever you've got, THEN treat it with medal-ready, then clean it, then spray the area with zinc-chromate weld-through primer and weld your patches on. Then POR-15 it if you want. Be sure you metal-ready, clean, and zinc-prime the underside of the patch area and inside the suspension console/hollow frame area as best you can before you close up the hole. It'll be good for another 30 years. Also check the firewall near your patch area shown - it may be thinner than you think down there at the corner. Good luck - your car doesn't look in bad shape from the pictures. Definitely worth fixing, and you can do this repair in just a couple of hours, easy.
-Ben M.
Dman   How bad is it Doc?   Apr 2 2003, 12:29 PM
Dman   Stupid me, here is the picture.   Apr 2 2003, 12:32 PM
Dave_Darling   How much do you like this particular car? How muc...   Apr 2 2003, 12:46 PM
SirAndy   naaa, that's good! spray "Metal Ready" in ...   Apr 2 2003, 12:51 PM
airsix
Pompano Beach 914V8   Seems like no big deal, simple repair. I live on t...   Apr 2 2003, 01:31 PM
SirAndy   airsix is right. if you look at my second picture ...   Apr 2 2003, 01:31 PM
Jeroen   Wanna trade? Didn't think so... so quit your w...   Apr 2 2003, 01:42 PM
Dman   This is the only real rust on the car so I want to...   Apr 2 2003, 01:46 PM
airsix
  Apr 2 2003, 04:16 PM
Lawrence914-6   Anything is repairable. :)   Apr 2 2003, 06:41 PM
seanery   Man, Why is everyones car rusted in the same place...   Apr 2 2003, 06:43 PM
Lawrence914-6   Is that a serious question? Because the battery ...   Apr 2 2003, 06:46 PM
SirAndy   <...   Apr 2 2003, 06:53 PM
seanery   I can't believe I got passed by 2 people! ...   Apr 2 2003, 07:01 PM
Lawrence914-6   I only try to post when I'm convinced I'm ...   Apr 2 2003, 07:12 PM
seanery   Not me, I'd only have 25 posts.   Apr 2 2003, 07:17 PM
Dave Cawdrey   This topic, and these pics are making me feel grea...   Apr 2 2003, 07:22 PM
Bleyseng   This one was a goner too. Rusted right though the ...   Apr 2 2003, 07:45 PM
Bleyseng   try this again....   Apr 2 2003, 07:46 PM
MarkV   I thought I was the only one w/ a nasty hiding und...   Apr 2 2003, 10:49 PM
MarkV   The PO had duct tape over it.   Apr 2 2003, 10:52 PM
MarkV   It's an AZ car & the longitudinals look like n...   Apr 2 2003, 10:56 PM
Bleyseng   Take the motor out! Drill out the spot welds w...   Apr 2 2003, 11:29 PM
MarkV   I bought this air tool at Harbor Freight for the j...   Apr 2 2003, 11:51 PM
MarkV   Try this:   Apr 2 2003, 11:54 PM
SirAndy   nice tool there MarkV, i could have saved myself s...   Apr 2 2003, 11:57 PM
Bleyseng   Thats kind of trick... Geoff   Apr 2 2003, 11:58 PM
MarkV   What can I say; I am a sucker for tools, especiall...   Apr 3 2003, 12:09 AM
SirAndy   very nice indeed. i think i have to add that to my...   Apr 3 2003, 12:16 AM
Dave Cawdrey   :shades: Thats way cool. I am building a small ar...   Apr 3 2003, 03:02 AM
Dman   I'm feeling a lot better. Seems like my car ha...   Apr 3 2003, 10:58 AM
Bleyseng   Here is a pic of a rotten long. Even "Rusty" would...   Apr 3 2003, 02:41 PM
SirAndy   <...   Apr 3 2003, 02:45 PM
ChrisReale   Damn Geoff, no wonder you were sliding around so m...   Apr 3 2003, 02:56 PM
tahoward   So much rust for such a little car! What are ...   Apr 3 2003, 02:58 PM
Bleyseng   I pulled the fuel pump so I had the vise grips on ...   Apr 3 2003, 03:07 PM
Jeroen   wow, that even looks worse than mine! thanks ...   Apr 3 2003, 03:10 PM
MarkV   Yikes !! The tin worm never sleeps. :toil...   Apr 3 2003, 03:35 PM
r_towle   I have to say, living in the northeast you just to...   Apr 3 2003, 07:41 PM
Bleyseng   Jereon, from the pics of your car I have seen it d...   Apr 3 2003, 10:22 PM
Dman   I am almost done with thewelding rust repair in t...   Apr 16 2003, 10:41 AM
Brad Roberts   The factory uses a similar hole on the other side ...   Apr 16 2003, 11:37 AM
TimT   What rust? :rocketarena:   Apr 16 2003, 01:03 PM
Jeroen   Mine already has enuf 8" holes... no need to cut a...   Apr 16 2003, 01:09 PM
Bleyseng   It will be fine unless you drive the car on the st...   Apr 16 2003, 06:02 PM
Elliot Cannon   I got the same problem. Glad to see that mine is ...   Apr 16 2003, 07:00 PM
Curvie Roadlover   Geoff, when I looked at that pic of the rusty long...   Apr 16 2003, 08:51 PM
Bleyseng   Lots of cars in Seattle look like that, rusty long...   Apr 17 2003, 08:06 AM
Mark Henry   Good god man! Some of you Cali boy's are t...   Apr 17 2003, 09:25 AM
Dman   Elliot, I have been sceptical about Por-15 for a...   Apr 17 2003, 10:40 AM
- Lo-Fi Version Time is now: 11th July 2025 - 11:43 AM
