> any tips for tuning weber 34ict?
JOE M
post Aug 28 2009, 03:49 PM
Curious about how to set the carbs up.The timing is close but may be out slightly.I started by turning the air mixture screws all the way in and than backing both off by 2 1/2 turns to start. I let the car idle and than I move 1 side until the car runs rough than back off the other way about 1/2 turn.I did the same for the other side. It runs ok but pops through the exhaust every now and than.It gets better when I take the throtle linkage off.I think my biggest problem is seting the idle speed screw. Is there something I should do prior to starting any other alignment?I read the procedure but I am stumped. What typically causes it to pop through the exhaust?I did check the vacum on both sides and they are real close ( within 1 of each other).
r_towle
post Sep 2 2009, 06:59 AM
Custom Member
Flip the carbs side for side and flip the linkage around.
It will be a lot easier to get it tuned....and you will need tokeep tuning...
Also...I am not a huge fan of the drop links you have that came with the kit...they seem a bit loosey goosey...might make it really hard to get them perfect.
Tune the linkage with one drop link in place....get it running great.
Then...ever so gentle, put the other link in place so it takes no pressure to attach the link...it should fall into place...no pushing up or down on the cross bar arm, or the carb.
Rich
JOE M
post Sep 2 2009, 11:08 AM
QUOTE(r_towle @ Sep 2 2009, 05:59 AM) *
Rich
It looks like I have the same drop linkage as Chris. It is what came with the kit and I agree that it is not great. I did see a cool setup and I want to look into it deeper to see if it something I can make at my shop. See pic below. If I cant make it I will stay with what I have for now. As for now I am going to to flip the linkage around to face the other side and tune it.
JOE M   any tips for tuning weber 34ict?   Aug 28 2009, 03:49 PM
JOE M   By the way it seems to smoke through the breather....   Aug 28 2009, 03:52 PM
neil30076   By the way it seems to smoke through the breather...   Aug 28 2009, 04:20 PM
jmill   What typically causes it to pop through the exhau...   Aug 28 2009, 04:03 PM
McMark   Make sure to sync the airflow for the left/right c...   Aug 28 2009, 05:01 PM
JOE M   Make sure to sync the airflow for the left/right ...   Aug 28 2009, 06:25 PM
aircooledtechguy   Here's how I sync duals. . . First ensure al...   Aug 28 2009, 05:38 PM
McMark   I think this is a slightly improper description,...   Aug 28 2009, 06:43 PM
JOE M   I think this is a slightly improper description...   Aug 28 2009, 06:52 PM
aircooledtechguy   I think this is a slightly improper description, ...   Aug 29 2009, 10:14 AM
JOE M   [quote name='McMark' post='1208515' date='Aug 28 ...   Aug 29 2009, 10:31 AM
904svo   Try this. Just had a crazy problem an this fix ...   Aug 28 2009, 07:11 PM
JOE M   Try this. Just had a crazy problem an this fix...   Aug 28 2009, 07:46 PM
904svo   Try this. Just had a crazy problem an this fi...   Aug 28 2009, 11:18 PM
JOE M   [quote name='JOE M' post='1208536' date='Aug 28 2...   Aug 29 2009, 08:24 AM
904svo   [quote name='JOE M' post='1208536' date='Aug 28 ...   Aug 29 2009, 08:35 AM
McMark   Jake Raby sells a breather box. Chris Foley sells ...   Aug 28 2009, 07:32 PM
McMark   The exhaust can seem tight and still have a leak. ...   Aug 28 2009, 07:38 PM
McMark   The port with thr red cap should NOT be used for v...   Aug 28 2009, 09:40 PM
r_towle   if you exhaust is leaking, get a small 2*4 and hol...   Aug 28 2009, 10:53 PM
JOE M   Easy enough--how about for the vacum advance. Shou...   Aug 29 2009, 08:44 AM
McMark   Yup. VW did it with their dual single throat Sole...   Aug 29 2009, 11:11 AM
McMark   Oh, just remember to pull the balance tube and plu...   Aug 29 2009, 11:27 AM
hi4head   I installed a set of the Weber 34 ICT's last y...   Aug 30 2009, 08:48 PM
JOE M   I installed a set of the Weber 34 ICT's last ...   Aug 31 2009, 11:12 AM
McMark   You don't want to T your vacuum lines to atmos...   Aug 31 2009, 01:38 PM
r_towle   Two type of vacuum ports bud. the manifold vacuum ...   Aug 31 2009, 05:02 PM
hi4head   Joe, Rich is right on with his comments. If it he...   Sep 1 2009, 07:39 PM
jcd914   Finally, I have a short length of hose connected ...   Sep 2 2009, 01:43 PM
JOE M   Thanks for all your help. I installed all the conn...   Sep 2 2009, 05:02 AM
r_towle   Flip the carbs side for side and flip the linkage ...   Sep 2 2009, 06:59 AM
JOE M   Flip the carbs side for side and flip the linkage...   Sep 2 2009, 11:08 AM
r_towle   You can get what you have to work fine...really. I...   Sep 2 2009, 12:33 PM
hi4head   Joe, Sorry if this is hijacking your thread a litt...   Sep 3 2009, 06:55 PM
JOE M   Joe, Sorry if this is hijacking your thread a lit...   Sep 4 2009, 07:21 AM
- Lo-Fi Version Time is now: 27th September 2026 - 07:55 PM
