> Removing Transmission, Need advice and help..., Never pulled one before...
montoya 73 2.0
post Aug 16 2009, 12:37 AM
Lack of consideration to others, and Selfish!
I know the steps:
- take off 4 bolts tranny to engine
- unhook 2 tranny mounts in the back
- take off 2 axels
- take off shift linkage
- remove muffler/muffler hanger
- remove starter and wire to reverse switch
- remove speedo cable
- remove clutch cable
- disconnect tranny ground strap
(EDIT: Not necessarliy in correct order)
But whats the best way to remove without damaging:
Shift linkage (remove the Spam Can without damaging the clamp), speedo cable & clutch cable?
A few pictures of what I'm dealing with...
"Spam Can"
montoya 73 2.0
post Sep 2 2009, 04:46 PM
Wasn't thinking that far in advance, But i guess i should. I was just thinking about driveing through the neighborhoods in the morning on my way to work and trying to be nice about my exhaust being to loud.
Screw'em, they should be up at 6:45am like me! So inconsiderate of me!
montoya 73 2.0   Removing Transmission, Need advice and help...   Aug 16 2009, 12:37 AM
Mark Henry   Big nut on speedo drive, do it carefully and don...   Aug 16 2009, 01:04 AM
Dr Evil   4 bolts tranny to engine are LAST, unless you want...   Aug 16 2009, 01:31 AM
montoya 73 2.0   Thank you!   Aug 16 2009, 11:54 AM
Bristol   I just did this job last week (bad seal on trans s...   Aug 17 2009, 11:32 AM
montoya 73 2.0   Where and what exactly do I remove?   Aug 17 2009, 02:15 PM
Cupomeat   Ok, at the end of the shift rod, behind the bushin...   Aug 17 2009, 02:20 PM
montoya 73 2.0   Ok, at the end of the shift rod, behind the bushi...   Aug 17 2009, 02:57 PM
Dr Evil   The yellow arrow is the rear conical screw. There ...   Aug 17 2009, 06:30 PM
montoya 73 2.0   The yellow arrow is the rear conical screw. There...   Aug 17 2009, 11:04 PM
Dr Evil   PM and remind me. I will be making some this week ...   Aug 17 2009, 11:12 PM
montoya 73 2.0   I believe this sending unit has to be removed but ...   Aug 23 2009, 04:44 PM
Dave_Darling   Just unplug it; the wires have bullet-shaped conne...   Aug 23 2009, 04:55 PM
montoya 73 2.0   Just unplug it; the wires have bullet-shaped conn...   Aug 23 2009, 04:56 PM
montoya 73 2.0   Pulled out the Tranny the next day (Monday). But t...   Sep 1 2009, 11:11 PM
Dr Evil   Oh Shit! That is totally OK.   Sep 1 2009, 11:31 PM
montoya 73 2.0   Okay cool! Just checking. Quick question, Is ...   Sep 1 2009, 11:55 PM
Dr Evil   Sure, with enough money you can do anything. 2nd i...   Sep 2 2009, 12:18 AM
montoya 73 2.0   Sure, with enough money you can do anything. 2nd ...   Sep 2 2009, 04:49 PM
jimkelly   rpm's high - you want to drive in the gear tha...   Sep 2 2009, 09:51 AM
montoya 73 2.0   Wasn't thinking that far in advance, But i gue...   Sep 2 2009, 04:46 PM
- Lo-Fi Version Time is now: 3rd November 2026 - 11:23 AM
