Gated shifer? |
Gated shifer? |
kyhunting |
Jul 20 2009, 11:03 AM
Newbie Group: Members Posts: 14 Joined: 8-October 07 From: KY Member No.: 8,199 |
Racing application. Who is using a gated shifter? Which one? Do you like it? Is it worth the expense? I've been fighting with shifting issues.. like finding 2nd when looking for 4th. Last episode ended with broken rocker arms. I've adjusted and replaced everything from the shifter to the solid trans mounts. It will do fine and then all of a sudden I've found second instead of 4th which results in a over rev. I have concentrated on my shifting and can't find a correlation to what causes this to happen. Any suggestions would be appriciated.
Thank you David |
HAM Inc |
Sep 9 2009, 11:26 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE No doubt you shift a bunch at the track, but as with all things it's a matter of degree when you compare an autox run to a track session or race. By degree I mean missed one shift at an autox and your finished. On the track this can also be the case, but typically it isn't. Yeah that makes sence. I imagine that in a short solo run (AX) you have to be flawless to get TTOD. I got lucky when I flubbed my shift as I wasn't being pressured in the braking zone. If I had, I would have likely lost the position. Sometimes one mistake is all it takes in any form of motorsports. |
grantsfo |
Sep 9 2009, 06:10 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
QUOTE No doubt you shift a bunch at the track, but as with all things it's a matter of degree when you compare an autox run to a track session or race. By degree I mean missed one shift at an autox and your finished. On the track this can also be the case, but typically it isn't. Yeah that makes sence. I imagine that in a short solo run (AX) you have to be flawless to get TTOD. I got lucky when I flubbed my shift as I wasn't being pressured in the braking zone. If I had, I would have likely lost the position. Sometimes one mistake is all it takes in any form of motorsports. Ahh Yeah that shift off the line from 1st to 2nd is tough. A good AX car doesnt get shifted out of 2nd at all in 95% of events. JP's car "shifting" at an AX. (IMG:style_emoticons/default/yellowsleep[1].gif) http://www.youtube.com/watch?v=7_nANXY8KBs...rofilepage#t=45 I can just say JWest linkage did wonders for my car and the stock kinkage that I replaced was relatively new. Brad and I installed it in about an hour. It helps to have two people for linkage install. Its not gated but shifts are much more positive. And I did hundreds of shifts flawlessly each weekend I went to the track with the JWest setup. Honestly shifting 901 with Jwest was nicer than my cable shifted Boxster. This post has been edited by grantsfo: Sep 9 2009, 06:18 PM |
Randal |
Sep 9 2009, 07:15 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
QUOTE No doubt you shift a bunch at the track, but as with all things it's a matter of degree when you compare an autox run to a track session or race. By degree I mean missed one shift at an autox and your finished. On the track this can also be the case, but typically it isn't. Yeah that makes sence. I imagine that in a short solo run (AX) you have to be flawless to get TTOD. I got lucky when I flubbed my shift as I wasn't being pressured in the braking zone. If I had, I would have likely lost the position. Sometimes one mistake is all it takes in any form of motorsports. Ahh Yeah that shift off the line from 1st to 2nd is tough. A good AX car doesnt get shifted out of 2nd at all in 95% of events. JP's car "shifting" at an AX. (IMG:style_emoticons/default/yellowsleep[1].gif) http://www.youtube.com/watch?v=7_nANXY8KBs...rofilepage#t=45 I can just say JWest linkage did wonders for my car and the stock kinkage that I replaced was relatively new. Brad and I installed it in about an hour. It helps to have two people for linkage install. Its not gated but shifts are much more positive. And I did hundreds of shifts flawlessly each weekend I went to the track with the JWest setup. Honestly shifting 901 with Jwest was nicer than my cable shifted Boxster. I think you are totally missing the point Grant. I wasn't talking about a 6 cylinder, where you rarely see 3rd, I was talking about my 4 cylinder where 3rd is used frequently. If you miss the 2nd to 3rd shift, because your right in the middle of a corner and on the rev limiter and have to shift, your done for that run. The point being that the RennShifter, at least the generation I have, doesn't correct this issue. Maybe with the "new" back end stuff it would. |
Lo-Fi Version | Time is now: 28th May 2024 - 02:26 PM |
