> 1.7 FI to carbs to install in a Bradley GT body, 9/15/09 update w/picts need an opinion from the experts
jays914
post Sep 10 2009, 05:21 PM
Attached ImageAttached Image
See additional pictues posted 9/15/09
Everyone,
I would like to know how much of a problem it would be to take 1.7 914 FI engine and convert it to a carbs to put into a Bradley GT project car. The body kit is an original 1976 model that was never put together. The Bradley was purchased by my cousin and I have the spare engine. The engine (in a barn for the last 15 years) will be torn down for inspection and parts replaced as needed.
Thought this would be a good way to reuse the 1.7 since most of the other comments I have heard or read for this type of engine were less than favorable.
Should the engine get a big bore kit, cam, dist, low pressure fuel pump? If so, does anyone have the required parts for the conversion? How much?
Thanks for your input!
Jays914
VaccaRabite
post Sep 10 2009, 06:47 PM
En Garde!
QUOTE(jays914 @ Sep 10 2009, 06:21 PM) *
Hi Jay, sounds like a cool project. Got any pictures of the kit?
if you have a 1.7, it is pretty easy to turn it into a 1911 using a lot of the parts you have on hand.
You will want a new cam, and you will need to have head work done by someone competent.
The 1911 used the stock 1.7 crank and case. Heads will need to be flycut to accept 96mm cylinders while they are checked out for cracks, seats and valves.
You will need to source 96mm pistons and cylinders. I used 2L cylinders and had them bored out to 96, and used 96mm Keith Black flat top pistons.
For the cam, you are going to want to change a lot of the valve train. You will have to cut new pushrods, you will need new lifters (that match the cam). You already have the desired 1.7 rockers, so it will be an easy move to go to the Elephant foot valve arms. Jake Raby's cam kits are pricey, but they will come with all the stuff you need, and he or Blake will work with you to choose the best cam grind for your application.
Or, you can call Web. Cheaper, and be sure to buy the matching lifters or cam life will be reduced.
All in all, figure probably around $2K-$3K to build the engine when you have accounted for head work, balancing, parts, etc.
OR. Call (okay, PM) McMark and ask about his $5K plug and play 2056. He builds it, you bolt it in. Its a pretty sweet deal.
Zach
jays914   1.7 FI to carbs to install in a Bradley GT body   Sep 10 2009, 05:21 PM
dlo914   You could up the size by going with 96mm pistons a...   Sep 10 2009, 06:35 PM
SLITS   If you are asking if it will fit ... I have no ide...   Sep 10 2009, 06:41 PM
Vacca Rabite   Thought this would be a good way to reuse the 1.7...   Sep 10 2009, 06:47 PM
jays914   Hey guys thanks for the great input! I'll...   Sep 13 2009, 02:31 PM
Dave_Darling   The 96es will make for the 1911cc engine, not 1988...   Sep 13 2009, 07:37 PM
jays914   Dave, Yet more great advise..... Thanks! Jay...   Sep 13 2009, 08:31 PM
jmill   I believe the Bradley was built on a bug pan. I...   Sep 13 2009, 09:07 PM
bfrymire   Everyone, I would like to know how much of a pro...   Sep 13 2009, 09:54 PM
Vacca Rabite   (I know this is not Jay's car. Well, maybe it...   Sep 14 2009, 12:43 PM
Cap'n Krusty   You're gonna need a conversion flywheel and a ...   Sep 14 2009, 12:51 PM
jays914   More pictures 9/15/09   Sep 15 2009, 07:46 PM
jays914   Yet another picture 9/15/09   Sep 15 2009, 07:49 PM
jays914   One last picture for today 9/15/09   Sep 15 2009, 07:52 PM
Vacca Rabite   Since you already have a 914 engine, why not use a...   Sep 15 2009, 08:10 PM
jays914   Since you already have a 914 engine, why not use ...   Sep 15 2009, 09:00 PM
Vacca Rabite   Jay, All I can say is that it has been done. You...   Sep 15 2009, 09:37 PM
Dave_Darling   It will fit with some beating, and maybe a little ...   Sep 15 2009, 09:38 PM
jays914   Zach and Dave, Thanks for the latest info! ...   Sep 17 2009, 01:06 PM
r_towle   Stick with all beetle parts...it will be easier. T...   Sep 17 2009, 01:24 PM
jays914   Stick with all beetle parts...it will be easier. ...   Sep 17 2009, 03:43 PM
Vacca Rabite   I suddenly have this thought in my head that a Bra...   Sep 17 2009, 07:42 PM
jays914   I suddenly have this thought in my head that a Br...   Sep 18 2009, 08:14 AM
maf914   I have seen various articles on the VW/901 tranny ...   Sep 19 2009, 01:59 PM
jays914   I have seen various articles on the VW/901 tranny...   Sep 20 2009, 07:50 AM
jays914   Check out the new pictures of the 1.7 engine teard...   Sep 26 2009, 03:47 PM
jays914   1.7 engine with tins removed...look what I found.....   Sep 26 2009, 04:29 PM
Bleyseng   yep, mice love it inside the tins as a nest...so c...   Sep 26 2009, 10:53 PM
jays914   yep, mice love it inside the tins as a nest...so ...   Sep 28 2009, 11:24 AM
Vacca Rabite   The parts from an engine tear down build quickly, ...   Sep 28 2009, 12:45 PM
- Lo-Fi Version Time is now: 19th April 2026 - 03:58 AM
