FS: 914 Parts! Paypal is now accepted! |
914rrr |
Sep 4 2009, 12:10 PM
Senior Member Group: Members Posts: 1,835 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
This is the last of our parts! We found a tub at the back of our storage that had more 914 parts! So we will be adding parts as we go through the tub.
We can provide photos upon request. Email us at 914rrr@comcast.net. Most prices are negotiable, especially if you buy multiple items. If you want to pay by paypal, please add 3% to the sales price. Thanks! Rob 865-463-2575 MPS 041/051E: Tested / works: $25 Caliper Kit (NEW - not sure if front or rear): $15 Heater ext tube with flapper box: $10 Heater ext tubes (pair): $15 J tubes (pair) 1 is missing top tab: $15 Jack straps A (pair) - excellent condition. no tears in the rubber: $40 Jack straps B (pair) - rubber is excellent. metal base is corroded: $30 Odometer reset cable: $10 Rain tray funnels w/tubes and seals (pair)- I may have 3 or 3 pairs: $30 per pair Shift rod boot (late) for firewall end. Very pliable: $25 Trunk targa top holders rear rubber (pair) w/bolts - used but no cracks: $25 Turn signal light seals (pair): $10 NOS Vacuum elbows for FI: $5 each. I have several. Visor mounts - set: $20. I have 3 or 4 sets. OEM Window cranks w/mounting washer and bolts (pair): $15 Pair of Gray Injector Boots. used but in great condition: $20 for the pair Lug nut covers - Qty 16: $12 for all Star lug bolts qty 16: $40 for all Star lug bolt qty 5: $2.50 each Lug bolts (steel wheels) Qty 11 plus 1 oddball: $7 Alloy lugs full set OEM A: $50 for the set Alloy lugs full set OEM B: $50 for the set Alloy lugs full set OEM C: $50 for the set Alloy lugs OEM qty 3: $3 each Interior mirror (late) very good condition: $30 Rear trunk locks (2) some pitting on both: 1 with key, 1 w/o key and back lever missing: $40 for both. Bra very good cond: $30 Auxillary Oil Cooler w/ sandwich adaptor, Aeroquip lines and fittings - exc cond. removed from my low mileage 914 turbo show car. easy screw on installation: $70 Door handles and ignition lock set with keys. drivers handle in good cond, pass side is broken. some pitting.: $35 Rear trunk latches (set - I have two sets): $20 per set Shift linkage with front coupler, rod, rear coupler, rear boot, and cover. Coupler and front boot are in exc cond, rear boot is dry and cover has a crack: $100 obo for the group SS heater box ext tubes (pair): $50 Air deflector plate - early - drivers side: $10 S tubes (pair with clamps - 2 pairs): $40 per pair J tubes (pair) good cond, all tabs intact: $25 obo |
zymurgist |
Sep 11 2009, 12:43 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I might want the dash switches... does this include the headlight switch? If so, how many terminals?
Also, do you know what type of wheel the center cap fits? |
914rrr |
Sep 11 2009, 03:02 PM
I might want the dash switches... does this include the headlight switch? If so, how many terminals? Also, do you know what type of wheel the center cap fits? It does include the headlight switch. It has 11 terminals. Center wheel caps fits all OEM 914 alloy wheels. |
Lo-Fi Version | Time is now: 12th June 2024 - 04:00 AM |
