> Head Gaskets
brandomc
post Sep 16 2009, 04:48 PM
I bought a engine last week that was supposedly a 1.7, but the guy didnt really know for sure. After looking at the case numbers, I think it might be a 1.8?? It starts with EB. I took all of the sheetmetal off to repaint it, and everything is really clean accept for around 1 of the cylinders between the head and the cylinder, it is black and kindof oily. I figure this is a leaky cylinder. Do i need new head gaskets? Or just retorque the head? Where do i get head gaskets? Pelican parts doesnt sell them. What should i do with this? It is supposed to be a fairly low mileage engine. Thanks
brandomc
post Sep 17 2009, 10:32 AM
So last night i ran a leak down test on this 1.7, and it wasn't good. Every cylinder was in the bad range accept for one in the moderate. I also did a leakdown test on the 2.0 that i picked up last week; the one that was "rebuilt" and never ran. That engine didnt test very well either. Looking in the ports, it does look like the heads were gone through, but i suspect the engine sat for a long time. Is is normal to get very much leakage through the valves when the engine is cold??
Im stuck now. I wanted this 1.7 to go into my car with little effort so that i could put all my thought into the 2.0. Now it is looking like they might both need alot of work, so maybe i should dump the 1.7 and just focus on the 2ltr? Any input on this guys?
Thanks
brandomc   Head Gaskets   Sep 16 2009, 04:48 PM
southernmost914   EB is a 1973 1.7 Calif. motor according to my boo...   Sep 16 2009, 05:00 PM
Vacca Rabite   It is surely a leak. If you did a compression and...   Sep 16 2009, 05:06 PM
brandomc   It is surely a leak. If you did a compression an...   Sep 16 2009, 05:12 PM
Vacca Rabite   So, it sounds like i shoud take the head off and ...   Sep 16 2009, 05:25 PM
brandomc   So, it sounds like i shoud take the head off and...   Sep 16 2009, 05:33 PM
aircooledtechguy   I would pull the head and see if there is a gasket...   Sep 16 2009, 05:13 PM
brandomc   I would pull the head and see if there is a gaske...   Sep 16 2009, 05:21 PM
Cap'n Krusty   I would pull the head and see if there is a gask...   Sep 16 2009, 06:27 PM
aircooledtechguy   I DO NOT agree. 36 Years of T4 experience, all ...   Sep 17 2009, 11:11 AM
r_towle   If you have head gaskets, removing them will raise...   Sep 16 2009, 05:50 PM
Vacca Rabite   Well, yes. In theory. But, you are in LA. proba...   Sep 16 2009, 05:54 PM
brandomc   Back to the begining; where can i get head gaskets...   Sep 16 2009, 06:14 PM
Vacca Rabite   Auto Atlanta, GPR, pm Capt. Krusty for them. Zach   Sep 16 2009, 06:19 PM
McMark   If you insist on running them (WHY?) I probably ha...   Sep 16 2009, 06:20 PM
brandomc   If you insist on running them (WHY?) I probably h...   Sep 16 2009, 06:26 PM
brandomc   So last night i ran a leak down test on this 1.7, ...   Sep 17 2009, 10:32 AM
McMark   The EB motor is the lowest compression 1.7, too. ...   Sep 17 2009, 11:36 AM
Vacca Rabite   What were the values that you were getting on the ...   Sep 17 2009, 07:47 PM
brandomc   What were the values that you were getting on the...   Sep 18 2009, 10:43 AM
Vacca Rabite   What were the values that you were getting on th...   Sep 18 2009, 11:23 AM
r_towle   [quote name='brandomc' post='1215876' date='Sep 1...   Sep 18 2009, 03:12 PM
Vacca Rabite   :poke: :poke: the first time? :poke: :poke: ...   Sep 18 2009, 03:52 PM
JazonJJordan   [quote name='r_towle' post='1215955' date='Sep 18...   Sep 18 2009, 11:16 PM
ME733   :popcorn: .....Well an 80..percent leakdown...soun...   Sep 18 2009, 11:59 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:45 PM
