| skiking |
Sep 16 2009, 09:28 PM
Newbie ![]() Group: Members Posts: 23 Joined: 15-September 09 From: Rapid City Member No.: 10,811 Region Association: None |
I recently had the brake calipers and lines replaced on my '75 teener. When I got it back from the shop, the brake warning flasher light was on all the time. The shop said they tried to fix it, but i'm not sure they knew what they were doing.
The pedal feels a little soft, but the brakes work and the reservoir is full. Any ideas what could be causing the brake warning light to flash whenever the car is running? Thanks, Robbie |
| marks914 |
Sep 17 2009, 02:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Push your e-brake handle all the way down.
Mark |
skiking Brake warning light problem Sep 16 2009, 09:28 PM
zx-niner
I recently had the brake calipers and lines repla... Sep 16 2009, 10:10 PM
Rod
I recently had the brake calipers and lines repl... Sep 17 2009, 06:32 AM
flat4
Believe it or not, there is a re-set switch on t... Sep 17 2009, 07:04 AM
jt914-6
[quote name='Rod' post='1215466' date='Sep 17 200... Sep 17 2009, 05:52 PM
skiking
I recently had the brake calipers and lines repl... May 31 2010, 06:28 PM
jsayre914
Mark
... Sep 17 2009, 06:15 PM
bdstone914 If your master cylinder does not have a reset on t... Sep 17 2009, 02:10 PM
flat4
If your master cylinder does not have a reset on ... Sep 17 2009, 06:31 PM
mpoffers I'm in the same boat. Single brown wire, no r... Feb 6 2010, 01:42 PM
skiking
If your master cylinder does not have a reset on ... May 31 2010, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 11:26 AM |
