| brandomc |
Sep 16 2009, 04:48 PM
Member ![]() ![]() Group: Members Posts: 113 Joined: 14-May 09 From: los angeles california Member No.: 10,363 Region Association: Southern California |
I bought a engine last week that was supposedly a 1.7, but the guy didnt really know for sure. After looking at the case numbers, I think it might be a 1.8?? It starts with EB. I took all of the sheetmetal off to repaint it, and everything is really clean accept for around 1 of the cylinders between the head and the cylinder, it is black and kindof oily. I figure this is a leaky cylinder. Do i need new head gaskets? Or just retorque the head? Where do i get head gaskets? Pelican parts doesnt sell them. What should i do with this? It is supposed to be a fairly low mileage engine. Thanks
| VaccaRabite |
Sep 17 2009, 07:47 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
What were the values that you were getting on the leak down? Remember they will be a little low due to the engine not being warmed up.
Tell you what I would do. Stick it in the car and run it till it breaks. Put your effort into the 2.0, and get it built ASAP. Don't put any money into the 1.7 that you can avoid. it will get the car on the road and if it only lasts a season, who cares. If it still runs when you pull it, sell it to someone else. Zach |
| brandomc |
Sep 18 2009, 10:43 AM
What were the values that you were getting on the leak down? Remember they will be a little low due to the engine not being warmed up. Tell you what I would do. Stick it in the car and run it till it breaks. Put your effort into the 2.0, and get it built ASAP. Don't put any money into the 1.7 that you can avoid. it will get the car on the road and if it only lasts a season, who cares. If it still runs when you pull it, sell it to someone else. Zach Thats what some of my other mechanic friends said to do also, so im going to try that. Its not like it is that hard to pull these engines out, so its worth a try. The numbers on the leakdown were in the 80% leakage range. It was hissing out the valves really bad. Once the motor runs and warms up a bit, hopefully they will seat better. Yeah, i want to focus my time and money on the 2.0 and build a 2056 or something bigger maybe. |
| VaccaRabite |
Sep 18 2009, 11:23 AM
What were the values that you were getting on the leak down? Remember they will be a little low due to the engine not being warmed up. Tell you what I would do. Stick it in the car and run it till it breaks. Put your effort into the 2.0, and get it built ASAP. Don't put any money into the 1.7 that you can avoid. it will get the car on the road and if it only lasts a season, who cares. If it still runs when you pull it, sell it to someone else. Zach Thats what some of my other mechanic friends said to do also, so im going to try that. Its not like it is that hard to pull these engines out, so its worth a try. The numbers on the leakdown were in the 80% leakage range. It was hissing out the valves really bad. Once the motor runs and warms up a bit, hopefully they will seat better. Yeah, i want to focus my time and money on the 2.0 and build a 2056 or something bigger maybe. Once I had my parts in hand and the balancing done, my 2056 was built in a week. granted, I took the week off to build it. But the point is that it does not have to take a long time. And I'm a total noob with building motors. Zach |
| r_towle |
Sep 18 2009, 03:12 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
What were the values that you were getting on the leak down? Remember they will be a little low due to the engine not being warmed up. Tell you what I would do. Stick it in the car and run it till it breaks. Put your effort into the 2.0, and get it built ASAP. Don't put any money into the 1.7 that you can avoid. it will get the car on the road and if it only lasts a season, who cares. If it still runs when you pull it, sell it to someone else. Zach Thats what some of my other mechanic friends said to do also, so im going to try that. Its not like it is that hard to pull these engines out, so its worth a try. The numbers on the leakdown were in the 80% leakage range. It was hissing out the valves really bad. Once the motor runs and warms up a bit, hopefully they will seat better. Yeah, i want to focus my time and money on the 2.0 and build a 2056 or something bigger maybe. Once I had my parts in hand and the balancing done, my 2056 was built in a week. granted, I took the week off to build it. But the point is that it does not have to take a long time. And I'm a total noob with building motors. Zach (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif) the first time? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif) |
| VaccaRabite |
Sep 18 2009, 03:52 PM
(IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif) the first time? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif) Hush you. I'm cheerleading and building confidence here. (IMG:style_emoticons/default/bootyshake.gif) Zach |
brandomc Head Gaskets Sep 16 2009, 04:48 PM
southernmost914 EB is a 1973 1.7 Calif. motor according to my boo... Sep 16 2009, 05:00 PM
Vacca Rabite It is surely a leak. If you did a compression and... Sep 16 2009, 05:06 PM
brandomc
It is surely a leak. If you did a compression an... Sep 16 2009, 05:12 PM
Vacca Rabite
So, it sounds like i shoud take the head off and ... Sep 16 2009, 05:25 PM
brandomc
So, it sounds like i shoud take the head off and... Sep 16 2009, 05:33 PM
aircooledtechguy I would pull the head and see if there is a gasket... Sep 16 2009, 05:13 PM
brandomc
I would pull the head and see if there is a gaske... Sep 16 2009, 05:21 PM
Cap'n Krusty
I would pull the head and see if there is a gask... Sep 16 2009, 06:27 PM
aircooledtechguy
I DO NOT agree. 36 Years of T4 experience, all ... Sep 17 2009, 11:11 AM
r_towle If you have head gaskets, removing them will raise... Sep 16 2009, 05:50 PM
Vacca Rabite Well, yes. In theory.
But, you are in LA. proba... Sep 16 2009, 05:54 PM
brandomc Back to the begining; where can i get head gaskets... Sep 16 2009, 06:14 PM
Vacca Rabite Auto Atlanta, GPR, pm Capt. Krusty for them.
Zach Sep 16 2009, 06:19 PM
McMark If you insist on running them (WHY?) I probably ha... Sep 16 2009, 06:20 PM
brandomc
If you insist on running them (WHY?) I probably h... Sep 16 2009, 06:26 PM
brandomc So last night i ran a leak down test on this 1.7, ... Sep 17 2009, 10:32 AM
McMark The EB motor is the lowest compression 1.7, too. ... Sep 17 2009, 11:36 AM
JazonJJordan
[quote name='r_towle' post='1215955' date='Sep 18... Sep 18 2009, 11:16 PM
ME733 :popcorn: .....Well an 80..percent leakdown...soun... Sep 18 2009, 11:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:43 PM |
