Rear Defog, Where does switch go?? |
Ian Stott |
Sep 19 2009, 10:58 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I have a 73 2.0 that was originally from California, I also have from my parts car a rear window with the defroster wires. Where would the switch go and where would I get it?
Ian Stott Moncton Canada |
914Sixer |
Sep 19 2009, 04:07 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You might want to see if the window grid is any good. Take a volt/ohm meter and put each one of the leads on the clips. You should see a direct short or 0 ohms. Anything else means the grid is open and will not heat. Most grids are open. Not sure if you can get the paint anymore to repair grids as the wires are now embeded in the glass.
Lo-Fi Version | Time is now: 11th June 2024 - 12:45 AM |
