silverteener |
Member ![]() ![]() Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 ![]() |
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now! |
silverteener |
I cut off the rubber grommet from the relay and all the connections and plugged them back in. fuse still blew. I traced the blue/white wire up to the tach and pulled it out of the harness. There was a small spot where the wire was rubbed down. I put another fuse in and made sure the blue/white wire was away from any metal and not touching #31 on the relay. fuse still blew! (IMG:style_emoticons/default/headbang.gif)
Lo-Fi Version | Time is now: 8th July 2025 - 09:48 PM |
