| ME733 |
Jul 5 2009, 12:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
You have asked about the fuchs which came on my 914 S....here goes...the O.E.M. spare rim is dated 8-72...and so are all the others.....and they are part#...914.361.011.00 .They look different in /on the backside than THE PHOTOGRAPH with notes you have shown......as a point of intrest the spare RIM and ALL the four on the ground are identical in every way...EXCEPT the four on the ground have a Painted BACKGROUND.....and after looking closely with a magnifing glass its obvious they are painted...and not quite dead flat black....they are Not anodized....the spare tire is an original tire ..DUNLOP 165 hr 15....looks like it and the rim have NEVER been used...the rim is clean and perfect (both sides and the tire has full tread....and is not dry rotted.(cracks showing in sidewalls)..However,.I would never consider using it obviously. (IMG:style_emoticons/default/bye1.gif)
| ME733 |
Jul 5 2009, 10:55 PM
Tom...this is murray.,,I found your questions intresting.,and it was informative to me personally to "discover" facts about my fuchs that I just never thought about. maybe this information will be of use to someone...this helps me toward conferming that I really do have a real 1973 2.0 S. this car has every option except a heated rear window. I must say that I prefer the look of the mahle wheels which were also available. I suppose you could have a choise at the dealer, but I am pretty sure the 2.0 S came with the fuchs as a standard equipment , maxed out, upgraded "super car!!!!" 914. for 1973. I prefer the original FUCHS unpainted look also, could you assist in helping me find the article/ info you mentioned to remove the paint safely. (IMG:style_emoticons/default/bye1.gif)
| ME733 |
Sep 21 2009, 09:29 AM
Tom...this is murray.,,I found your questions intresting.,and it was informative to me personally to "discover" facts about my fuchs that I just never thought about. maybe this information will be of use to someone...this helps me toward conferming that I really do have a real 1973 2.0 S. this car has every option except a heated rear window. I must say that I prefer the look of the mahle wheels which were also available. I suppose you could have a choise at the dealer, but I am pretty sure the 2.0 S came with the fuchs as a standard equipment , maxed out, upgraded "super car!!!!" 914. for 1973. I prefer the original FUCHS unpainted look also, could you assist in helping me find the article/ info you mentioned to remove the paint safely. (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) Tom ...This is murray well the 914 S I have came with three set of rims . one set was the "fuchs" we were discussing, and the other two are "mahle"s. the UPDATE is simply that I have removed the background Black paint on the Fuchs .(why in hell the P.O. had these painted is beyond me). The paint was crappy, which was good ...as it came off resonably easy, with paint stripper and brake kleen. Then I did a little polishing , with a little corse rubbing compound to do some deep cleaning, and then fine polished with fine rubbing compound . The "spokes" were compounded and polished to a new condition, all done by HAND....the "spokes " came highly polished as compaired to the recessed spokes. there was no anidization, or optical illusion factor. The wheels are back to O.E.M. apperance...and look GREAT!. I steamed cleaned (again) both sets of "MAHLE,s". and found an exact color match of (for ) spraying painting these wheels...one set is finished. but I cannot decide which, or what brand of clear coat to use. Seems like there are some choises, but I dont want them hazing over, or turning yellow If the clear coat is crap. I am very fortunate to have gotten so many O.E.M. spares with the car. I appreciate all of you guys input . about "wheels". thanks. If there were a symbol for work your ass off I would have used it here.(polishing). (IMG:style_emoticons/default/popcorn[1].gif) |
| Tom_T |
Sep 21 2009, 02:13 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Tom...this is murray.,,I found your questions intresting.,and it was informative to me personally to "discover" facts about my fuchs that I just never thought about. maybe this information will be of use to someone...this helps me toward conferming that I really do have a real 1973 2.0 S. this car has every option except a heated rear window. I must say that I prefer the look of the mahle wheels which were also available. I suppose you could have a choise at the dealer, but I am pretty sure the 2.0 S came with the fuchs as a standard equipment , maxed out, upgraded "super car!!!!" 914. for 1973. I prefer the original FUCHS unpainted look also, could you assist in helping me find the article/ info you mentioned to remove the paint safely. (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) Tom ...This is murray well the 914 S I have came with three set of rims . one set was the "fuchs" we were discussing, and the other two are "mahle"s. the UPDATE is simply that I have removed the background Black paint on the Fuchs .(why in hell the P.O. had these painted is beyond me). The paint was crappy, which was good ...as it came off resonably easy, with paint stripper and brake kleen. Then I did a little polishing , with a little corse rubbing compound to do some deep cleaning, and then fine polished with fine rubbing compound . The "spokes" were compounded and polished to a new condition, all done by HAND....the "spokes " came highly polished as compaired to the recessed spokes. there was no anidization, or optical illusion factor. The wheels are back to O.E.M. apperance...and look GREAT!. I steamed cleaned (again) both sets of "MAHLE,s". and found an exact color match of (for ) spraying painting these wheels...one set is finished. but I cannot decide which, or what brand of clear coat to use. Seems like there are some choises, but I dont want them hazing over, or turning yellow If the clear coat is crap. I am very fortunate to have gotten so many O.E.M. spares with the car. I appreciate all of you guys input . about "wheels". thanks. If there were a symbol for work your ass off I would have used it here.(polishing). (IMG:style_emoticons/default/popcorn[1].gif) Hey Murray.....Glad to hear you got those Fuchs 2L alloys back to the OE look. I'd ask some of the originality folks about the proper finish for the Mahle 4 lugs, as I thought they were also satin & semi-polished like the Fuchs 2Ls - I think the rim edge & top of ribs were semi-polished, with a satin background. Maybe McMark, Pat Garvey or someone knows???? (IMG:style_emoticons/default/confused24.gif) I'm heading for the same hard work myself, as I picked up a set of 5 Fuchs 2L alloys for my 914S (...sorry Pat, btw apparently Porsche AG allowed the UK to keep the 914SC marketing name, but no badges as such). A couple of POs &/or Dealer first primed them with the green zinc then painted them Signal Orange or Phoenix Red, then another PO painted silver over that. It appears that the paint may have actually preserved the OE finish - I hope, but that has to wait for other projects to get mine fixed/painted & running! (IMG:style_emoticons/default/dry.gif) |
ME733 more about Fuchs Jul 5 2009, 12:00 PM
Tom_T Thanx - great info ME733,
Your info proves that t... Jul 5 2009, 04:08 PM
Pat Garvey Two things here, and the post will be moved to the... Jul 6 2009, 08:17 PM
Tom_T BTW Pat -
Because the early hubs were flat ... Jul 6 2009, 10:34 PM
McMark
Anodizing in an electrical process involving cath... Jul 7 2009, 07:12 PM
RobW
Anodizing in an electrical process involving cat... Jul 7 2009, 08:50 PM
Pat Garvey
Anodizing in an electrical process involving ca... Jul 7 2009, 09:11 PM
Tom_T
Anodizing in an electrical process involving cat... Jul 7 2009, 09:49 PM
Tom_T
Anodizing in an electrical process involving cat... Jul 7 2009, 10:21 PM
orthobiz
So McMark - on those 2L alloys - did they color ... Jul 11 2009, 10:20 PM
McMark So McMark - on those 2L alloys - did they color th... Jul 22 2009, 04:22 PM
Tom_T
So McMark - on those 2L alloys - did they color t... Jul 22 2009, 04:39 PM
Bleyseng
[quote name='McMark' post='1194209' date='Jul 22 ... Sep 21 2009, 10:35 PM
Tom_T
[quote name='McMark' post='1194209' date='Jul 22... Sep 21 2009, 10:52 PM
Tom_T Listing of several wheel refinishers on both coast... Jul 7 2009, 10:09 PM
Tom_T I suppose the background could be more of a raw un... Jul 11 2009, 11:30 PM
6freak new Fuchs now available through Porsche ...$1... Jul 11 2009, 11:37 PM
Tom_T
new Fuchs now available through Porsche ...... Jul 11 2009, 11:46 PM
6freak
new Fuchs now available through Porsche ...... Jul 12 2009, 12:18 AM
Tom_T
new Fuchs now available through Porsche ...... Jul 12 2009, 12:11 PM
6freak Talk`n bout the 5 lugs.....From Porsche Design... Jul 13 2009, 09:35 AM
Tom_T
Talk`n bout the 5 lugs.....From Porsche Desig... Jul 14 2009, 12:55 AM
6freak If I keep buy`n fancy stuff I`ll never get... Jul 14 2009, 11:06 AM
ME733 :popcorn: Tom...I did ask an expert about the ... Sep 21 2009, 09:20 PM
Tom_T
:popcorn: Tom...I did ask an expert about the ... Sep 21 2009, 10:05 PM
Pat Garvey
:popcorn: Tom...I did ask an expert about the ... Sep 22 2009, 07:32 PM
Bleyseng I have used Wurth's silver as its a close matc... Sep 23 2009, 08:17 AM
ME733 :popcorn: George H at A.A. has the exact wurth col... Sep 23 2009, 11:50 PM
Tom_T
:popcorn: George H at A.A. has the exact wurth co... Sep 26 2009, 06:30 PM
davep In my experience there were 3 front brake rotors u... Sep 25 2009, 09:02 AM
ME733 :popcorn: Hello davep....Intresting obversavions i... Sep 25 2009, 08:26 PM
Tom_T Yes Murray, the Fuchs 2L were listed as "Forg... Sep 26 2009, 01:46 PM
ME733 :popcorn: TOM, ..Is this of any intrest?...my O.E.... Oct 2 2009, 12:13 PM
Tom_T
:popcorn: TOM, ..Is this of any intrest?...my O.E... Oct 2 2009, 03:43 PM
ME733 :popcorn: ...YES TOM this information does help...... Oct 3 2009, 08:03 AM
Tom_T
:popcorn: ...YES TOM this information does help..... Oct 3 2009, 10:56 AM
Jeff Bowlsby The correct link for the recall info is now: http... Oct 4 2009, 10:19 AM
Tom_T
The correct link for the recall info is now: htt... Oct 4 2009, 10:58 AM
Jeff Bowlsby Hi Tom, I did post the website links update a wee... Oct 5 2009, 02:49 PM
Tom_T
Hi Tom, I did post the website links update a we... Oct 5 2009, 03:54 PM
ME733 :popcorn: ...TOM...So in my wonderment ..about WHY... Oct 4 2009, 11:52 AM
Tom_T
:popcorn: ...TOM...So in my wonderment ..about WH... Oct 4 2009, 07:55 PM
ME733 :popcorn: TOM...the ...FUCHS forged wheels..(just... Oct 4 2009, 08:43 PM
Tom_T
:popcorn: TOM...the ...FUCHS forged wheels..(jus... Oct 4 2009, 10:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:06 PM |
