> I Found 4th and 5th, It's ALIVE - Thanks THOMAS & Dr. Evil!
ericread
post Sep 21 2009, 08:21 PM
The Viper Blue 914
I finished rebuilding my transmission at the SoCal Dr. Evil workshop last Saturday (9/19/09). Everything is ready to go, but I can't find 4th or 5th - it feels like it neutral where 4th and 5th should be.
I've read dozens of threads regarding adjusting the shift bar, but I'm still not smart enough to figure it out.
I am assuming I need to turn the shift bar a few splines either clockwise or counter-clockwise? Am I on the right track? How do I do that???
Reverse and 1st through 3rd work great.
Eric
ahdoman
post Sep 21 2009, 08:33 PM
It's phonetic...Ah-D-O-Man (Audioman)
Eric,
What did you expect for getting a deal? You have to pay extra for 4th & 5th!
Sorry, just had to push the button... it sounds like your linkage bar is misaligned, I assume you've lined up the cone screws (one at the trans coupling and one at the firewall? If so you'll need to adjust the shift bar where it connects to the shifter. Before you pull it out mark the orientation of the bar. Then pull it out and turn it clockwise (to the right) a spline or two. You may have to play with it a little to get it oriented so that it goes into every gear.
ericread
post Sep 21 2009, 08:40 PM
The Viper Blue 914
QUOTE(ahdoman @ Sep 21 2009, 07:33 PM) *
Eric,
Firstly, I DID pay Dr. Evil extra for 4th and 5th... Hmmm.....I wonder if the check cleared. (IMG:style_emoticons/default/idea.gif)
The cone screws are in and correct. So how do you move the shift bar clockwise? I had the bar apart a couple of times, but I couldn't seem to turn the bar clockwise... Should I have it in neutral before I detach the bar to do this?
Thanks for your advice in advance! (IMG:style_emoticons/default/beerchug.gif)
ericread   I Found 4th and 5th   Sep 21 2009, 08:21 PM
ahdoman   Eric, What did you expect for getting a deal? You ...   Sep 21 2009, 08:33 PM
ericread   Eric, What did you expect for getting a deal? You...   Sep 21 2009, 08:40 PM
davep   You can find 4th & 5th to the right of 2nd ...   Sep 21 2009, 08:36 PM
ClayPerrine   Ok.. here is the easy way. 1. Take off the cover ...   Sep 21 2009, 08:49 PM
computers4kids   Hey Eric, Clay's directions are pretty good. ...   Sep 21 2009, 09:43 PM
ericread   Well, I'm done for the evening (I'm really...   Sep 21 2009, 10:12 PM
ahdoman   Eric - bad news; remember, I helped you install th...   Sep 21 2009, 10:15 PM
ericread   Eric - bad news; remember, I helped you install t...   Sep 21 2009, 10:22 PM
ahdoman   What about 6th? Is it not working either? :chair:...   Sep 21 2009, 10:35 PM
Dave_Darling   If you adjust and adjust, and you still can't ...   Sep 22 2009, 01:30 AM
Dr Evil   I am glad Clay wrote it up.....I get tired of repe...   Sep 22 2009, 01:32 AM
charliew   I'm just lurking but this confuses me a little...   Sep 22 2009, 08:44 AM
degreeoff   Hey Doc, you ahhhh thinkin this maybe why my inard...   Sep 22 2009, 10:06 AM
ahdoman   Degreeoff - after my /6 rebuild and install (inclu...   Sep 22 2009, 10:20 AM
Dr Evil   If your internal shift forks are adjusted correctl...   Sep 22 2009, 10:31 AM
JazonJJordan   :popcorn: :popcorn: :popcorn: (my red racer ...   Sep 22 2009, 10:55 PM
ericread   OK - Here's the update. After trying to get 4...   Sep 22 2009, 08:22 PM
Dr Evil   Thomas is good people :) So your was the one with ...   Sep 22 2009, 10:25 PM
Dr Evil   OK, as I was falling a sleep this morning I rememb...   Sep 23 2009, 10:36 AM
ericread   OK, as I was falling a sleep this morning I remem...   Sep 23 2009, 11:01 AM
Dr Evil   Indeed, you have crossed the threshold into 4-5 wo...   Sep 23 2009, 11:21 AM
ericread   No Joy :( Dr. Evil; I replaced the ball pin-sh...   Sep 23 2009, 05:07 PM
Dr Evil   The only thing I can think of is that the 4-5 fork...   Sep 23 2009, 07:09 PM
ericread   The only thing I can think of is that the 4-5 for...   Sep 23 2009, 07:19 PM
computers4kids   The only thing I can think of is that the 4-5 fo...   Sep 24 2009, 09:02 AM
ClayPerrine   You don't have to remove the tranny, just drop...   Sep 24 2009, 08:10 AM
ericread   You don't have to remove the tranny, just dro...   Sep 24 2009, 11:44 AM
r_towle   Eric, I am really sorry that this happened to your...   Sep 24 2009, 09:53 AM
Dr Evil   :P Thomas checked all of your external linkage, ...   Sep 24 2009, 12:57 PM
ericread   :P Thomas checked all of your external linkage,...   Sep 24 2009, 01:48 PM
Dr Evil   If you are so inclined, when you have your box out...   Sep 24 2009, 01:20 PM
Dr Evil   You said I look old? I dont remember that. :D   Sep 24 2009, 01:53 PM
ericread   You said I look old? I dont remember that. :D I...   Sep 24 2009, 02:14 PM
r_towle   There are two things to look for when you are insp...   Sep 24 2009, 01:59 PM
Dr Evil   The twisted rod for 4-5 will either be obvious or ...   Sep 24 2009, 02:32 PM
ericread   IT IS ALIVE!!! I drove over to Thomas...   Sep 25 2009, 07:59 PM
396   IT IS ALIVE!!! I drove over to Thoma...   Sep 26 2009, 12:05 AM
Dr Evil   Doh! I am glad it is fixed. Sorry about that. ...   Sep 25 2009, 08:03 PM
ericread   One more item of note. While he was removing the ...   Sep 25 2009, 09:10 PM
Dr Evil   As much as I respect his opinion, I did the resear...   Sep 25 2009, 09:31 PM
T H O M A S   every body likes different nuts doc,so don't w...   Sep 25 2009, 10:52 PM
ericread   every body likes different nuts doc,so don't ...   Sep 26 2009, 12:58 AM
Dr Evil   Thomas, you are the man :) :hugme:   Sep 25 2009, 11:04 PM
RJMII   I am still trying to figure out why Eric needs 4th...   Sep 25 2009, 11:12 PM
ericread   I now have all the gears! THOMAS adjusted the...   Sep 26 2009, 05:24 PM
Sleepin   I can't believe you made Thomas work in the da...   Sep 26 2009, 05:53 PM
- Lo-Fi Version Time is now: 15th July 2025 - 02:56 AM
