> I Found 4th and 5th, It's ALIVE - Thanks THOMAS & Dr. Evil!
ericread
post Sep 21 2009, 08:21 PM
The Viper Blue 914
I finished rebuilding my transmission at the SoCal Dr. Evil workshop last Saturday (9/19/09). Everything is ready to go, but I can't find 4th or 5th - it feels like it neutral where 4th and 5th should be.
I've read dozens of threads regarding adjusting the shift bar, but I'm still not smart enough to figure it out.
I am assuming I need to turn the shift bar a few splines either clockwise or counter-clockwise? Am I on the right track? How do I do that???
Reverse and 1st through 3rd work great.
Eric
Dr Evil
post Sep 22 2009, 10:31 AM
Send me your transmission!
If your internal shift forks are adjusted correctly (and yours are, I did it), then your shifting issues are external. I am having a hard time with the clarity of your problems so I will address the top 3:
1. I cant find "insert gear numbers here"
If you cant find gears that are on the same plane; 1-3-5, R-2-4, 1-R, 4-5, then your shifter bar adjustment is off.
If you cant find 1-3-5 or R-2-4 then you need to loosen the pinch bolt and slide the shift lever TOWARDS the gears that you CAN find; if you have R-2-4 and need 1-3-5, move the lever more towards the front of the car when the bolt is loose. This will shorten the shift rod and give you more pull in the 1-3-5- plane.
***With your problem of not finding 4-5 you must adjust the L-R plane.
Q1. How do you know you have R-1, and 2-3? 2-3 can easily be in the R-1 position and 4-5 would then be in the 2-3 position. This would make you shifting seem to stop after 3rd gear. If this is the case you need to:
- Loosen the pinch bolt
- Move your stick shift towards the drivers side while keeping the shift rod in the tunnel from moving.
- Re-tighten the pinch bolt with the stick shift held in the new position
- Discover the missing gears.
Now you are ready to find the real second gear and adjust your shifter as stated in the post above.
2. After a rebuild, it is hard to get it into gear = need more strength.
This is perfectly normal for a while after a rebuild. Synchro bands vary in their stiffness and thus how easy they collapse. New ones are very stiff, older ones are easier to use. If your shift linkage is adjusted correctly, and it is not grinding when shifting, then you are fine and need to man up (IMG:style_emoticons/default/tongue.gif)
The newer/new synchro bands will cause any weak or worn out parts of your shift linkage to fail so fix it now or on the side of the road.
3. Grinds when going into gear or pops out of gear once in.
this is an actual problem. Grinding should not happen on a rebuild. Poping out of gear, so long as it is not that the linkage is not adjusted correctly, is not acceptable on a rebuild either.
1st will grind sometimes after a rebuild depending on if you are down shifting with the tranz still spooled up. It should not be more than minor, though and you need to check your clutch cable to make sure your clutch is totally disengaging.
Charlie,
you need to adjust the linkage every time you pull the engine or tranny. You will not be able to align the drive train exactly the same in the car and any movement of the drive train with relation to the car (where the shift linkage is affixed) will throw off the pattern. That is why bad engine or tranny mounts can cause shifting issues.
JazonJJordan
post Sep 22 2009, 10:55 PM
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
(my red racer "Please" is up on blocks as a 2-3, 4-5 gear only. I also has a pass side engine bar bolt shear off and shifty engine (Yuck!) so rustoration in progress. It was time....thanks for the tech-know guys!)
QUOTE(Dr Evil @ Sep 22 2009, 12:31 PM) *
Charlie,
ericread   I Found 4th and 5th   Sep 21 2009, 08:21 PM
ahdoman   Eric, What did you expect for getting a deal? You ...   Sep 21 2009, 08:33 PM
ericread   Eric, What did you expect for getting a deal? You...   Sep 21 2009, 08:40 PM
davep   You can find 4th & 5th to the right of 2nd ...   Sep 21 2009, 08:36 PM
ClayPerrine   Ok.. here is the easy way. 1. Take off the cover ...   Sep 21 2009, 08:49 PM
computers4kids   Hey Eric, Clay's directions are pretty good. ...   Sep 21 2009, 09:43 PM
ericread   Well, I'm done for the evening (I'm really...   Sep 21 2009, 10:12 PM
ahdoman   Eric - bad news; remember, I helped you install th...   Sep 21 2009, 10:15 PM
ericread   Eric - bad news; remember, I helped you install t...   Sep 21 2009, 10:22 PM
ahdoman   What about 6th? Is it not working either? :chair:...   Sep 21 2009, 10:35 PM
Dave_Darling   If you adjust and adjust, and you still can't ...   Sep 22 2009, 01:30 AM
Dr Evil   I am glad Clay wrote it up.....I get tired of repe...   Sep 22 2009, 01:32 AM
charliew   I'm just lurking but this confuses me a little...   Sep 22 2009, 08:44 AM
degreeoff   Hey Doc, you ahhhh thinkin this maybe why my inard...   Sep 22 2009, 10:06 AM
ahdoman   Degreeoff - after my /6 rebuild and install (inclu...   Sep 22 2009, 10:20 AM
Dr Evil   If your internal shift forks are adjusted correctl...   Sep 22 2009, 10:31 AM
JazonJJordan   :popcorn: :popcorn: :popcorn: (my red racer ...   Sep 22 2009, 10:55 PM
ericread   OK - Here's the update. After trying to get 4...   Sep 22 2009, 08:22 PM
Dr Evil   Thomas is good people :) So your was the one with ...   Sep 22 2009, 10:25 PM
Dr Evil   OK, as I was falling a sleep this morning I rememb...   Sep 23 2009, 10:36 AM
ericread   OK, as I was falling a sleep this morning I remem...   Sep 23 2009, 11:01 AM
Dr Evil   Indeed, you have crossed the threshold into 4-5 wo...   Sep 23 2009, 11:21 AM
ericread   No Joy :( Dr. Evil; I replaced the ball pin-sh...   Sep 23 2009, 05:07 PM
Dr Evil   The only thing I can think of is that the 4-5 fork...   Sep 23 2009, 07:09 PM
ericread   The only thing I can think of is that the 4-5 for...   Sep 23 2009, 07:19 PM
computers4kids   The only thing I can think of is that the 4-5 fo...   Sep 24 2009, 09:02 AM
ClayPerrine   You don't have to remove the tranny, just drop...   Sep 24 2009, 08:10 AM
ericread   You don't have to remove the tranny, just dro...   Sep 24 2009, 11:44 AM
r_towle   Eric, I am really sorry that this happened to your...   Sep 24 2009, 09:53 AM
Dr Evil   :P Thomas checked all of your external linkage, ...   Sep 24 2009, 12:57 PM
ericread   :P Thomas checked all of your external linkage,...   Sep 24 2009, 01:48 PM
Dr Evil   If you are so inclined, when you have your box out...   Sep 24 2009, 01:20 PM
Dr Evil   You said I look old? I dont remember that. :D   Sep 24 2009, 01:53 PM
ericread   You said I look old? I dont remember that. :D I...   Sep 24 2009, 02:14 PM
r_towle   There are two things to look for when you are insp...   Sep 24 2009, 01:59 PM
Dr Evil   The twisted rod for 4-5 will either be obvious or ...   Sep 24 2009, 02:32 PM
ericread   IT IS ALIVE!!! I drove over to Thomas...   Sep 25 2009, 07:59 PM
396   IT IS ALIVE!!! I drove over to Thoma...   Sep 26 2009, 12:05 AM
Dr Evil   Doh! I am glad it is fixed. Sorry about that. ...   Sep 25 2009, 08:03 PM
ericread   One more item of note. While he was removing the ...   Sep 25 2009, 09:10 PM
Dr Evil   As much as I respect his opinion, I did the resear...   Sep 25 2009, 09:31 PM
T H O M A S   every body likes different nuts doc,so don't w...   Sep 25 2009, 10:52 PM
ericread   every body likes different nuts doc,so don't ...   Sep 26 2009, 12:58 AM
Dr Evil   Thomas, you are the man :) :hugme:   Sep 25 2009, 11:04 PM
RJMII   I am still trying to figure out why Eric needs 4th...   Sep 25 2009, 11:12 PM
ericread   I now have all the gears! THOMAS adjusted the...   Sep 26 2009, 05:24 PM
Sleepin   I can't believe you made Thomas work in the da...   Sep 26 2009, 05:53 PM
- Lo-Fi Version Time is now: 15th July 2025 - 03:02 AM
