> Still no turn signals
silverteener
post Aug 22 2009, 02:12 PM
We'll..
I got another hazard switch today and still have no turn signals. I have replaced the turn signal lever and put a new relay in. I also checked the light bulbs and they are 1157's. I found a ground under the dash above the fuse box and it is tight. This thing is really starting a piss me off. I'm thinking it's going back on jackstands til next year. I'm at a lose and there is no one around here to take it too. Any more suggestions? It's a 72 that I would like to (IMG:style_emoticons/default/ar15.gif) right now!
silverteener
post Sep 23 2009, 04:36 PM
It's working!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Thanks to everyone for help, especially Spoke and 904svo. You guys were more than patient with me and my lack of electrical skills. Spoke actually gave him his number and last night he spent an hour on the phone with me tracing my short. We found it was in the turn signal lever. I had another one and swapped it out and now they work! Well, my right front turn signal is not working but I'm going to look at that tonight. I think a wire may have come off or the bulb is bad but last night I didn't care. I went driving around anyway
thanks again (IMG:style_emoticons/default/aktion035.gif)
silverteener   Still no turn signals   Aug 22 2009, 02:12 PM
type47   Only suggestions I can make are to find places in ...   Aug 22 2009, 03:16 PM
orange914   get a diagram and trace power from the fuse up, wi...   Aug 22 2009, 03:16 PM
silverteener   trying to work on this again. I had an exta fuse ...   Aug 27 2009, 07:49 PM
904svo   Let me know the results of this test, with key off...   Aug 27 2009, 09:37 PM
silverteener   came home for lunch so I could try it but I don...   Aug 28 2009, 11:50 AM
904svo   came home for lunch so I could try it but I don...   Aug 28 2009, 03:47 PM
Garold Shaffer   I'm at a lose and there is no one around her...   Aug 28 2009, 02:46 PM
silverteener   I didn't get any volts from either side on #9....   Aug 28 2009, 06:06 PM
904svo   I didn't get any volts from either side on #9...   Aug 28 2009, 06:40 PM
silverteener   on the top I got 12v but the bottom was sparking a...   Aug 28 2009, 08:12 PM
904svo   on the top I got 12v but the bottom was sparking ...   Aug 28 2009, 08:36 PM
silverteener   I took all the bulbs out and put a new fuse in and...   Aug 29 2009, 07:55 AM
904svo   You have a short in the circuit, goto to your auto...   Aug 29 2009, 08:32 AM
silverteener   I have a 3157 bulb but i'm confused on how to ...   Aug 29 2009, 12:44 PM
silverteener   I forgot you said it runs the interior light. I w...   Aug 29 2009, 12:47 PM
silverteener   Where does the interior light ground. I traced th...   Aug 29 2009, 01:05 PM
jt914-6   According to my diagram, the interior light ground...   Aug 29 2009, 01:27 PM
orange914   i eally dont understand it but i've seen weak ...   Aug 29 2009, 01:36 PM
silverteener   I cleaned that ground up and put the interior bulb...   Aug 29 2009, 01:51 PM
904svo   I cleaned that ground up and put the interior bul...   Aug 29 2009, 04:58 PM
ws91420   Shouldn't the turn signals be a 1156 single po...   Aug 29 2009, 02:19 PM
orange914   Shouldn't the turn signals be a 1156 single p...   Aug 29 2009, 03:51 PM
tod914   Try reseating all the connectors into the signal h...   Aug 29 2009, 05:07 PM
904svo   Try this if you can find the flasher relay check f...   Aug 29 2009, 09:43 PM
silverteener   Ok, I went and got 2 1156's for the front. ...   Aug 29 2009, 10:00 PM
904svo   Sounds like you have a bad relay, check this first...   Aug 29 2009, 10:22 PM
silverteener   with the key off and the left turn signal on my le...   Aug 29 2009, 10:35 PM
904svo   with the key off and the left turn signal on my l...   Aug 29 2009, 11:10 PM
silverteener   I'll have to order one. :( I think Pelican h...   Aug 29 2009, 11:21 PM
904svo   I'll have to order one. :( I think Pelican ...   Aug 30 2009, 09:47 AM
silverteener   I think I found one at O'Reillys. This one is...   Aug 31 2009, 06:15 PM
904svo   I think I found one at O'Reillys. This one i...   Aug 31 2009, 07:50 PM
silverteener   The new relay didn't work. I still have somet...   Aug 31 2009, 10:19 PM
drive-ability   The new relay didn't work. I still have some...   Sep 1 2009, 11:19 PM
jt914-6   That is "normal". It should do that. Tha...   Sep 1 2009, 05:55 AM
904svo   With the key off left turn signal on, Both front a...   Sep 1 2009, 10:55 AM
silverteener   who knows, I'm going to look at it more tonig...   Sep 2 2009, 11:59 AM
drive-ability   who knows, I'm going to look at it more toni...   Sep 2 2009, 12:40 PM
blazerchad   been dealing with turn signals on my 72 1.7.. fla...   Sep 6 2009, 12:59 PM
Rod   been dealing with turn signals on my 72 1.7.. fl...   Sep 6 2009, 01:10 PM
blazerchad   until I got a brand new OE relay, since then it h...   Sep 6 2009, 01:24 PM
Rod   until I got a brand new OE relay, since then it ...   Sep 6 2009, 01:31 PM
gothspeed   The new relay didn't work. I still have some...   Sep 16 2009, 04:19 PM
904svo   Do the 4 way flashers work? If not, check you have...   Sep 16 2009, 05:20 PM
silverteener   The 4 ways don't work. I do have 12v at the re...   Sep 16 2009, 09:31 PM
904svo   The 4 ways don't work. I do have 12v at the r...   Sep 16 2009, 09:56 PM
silverteener   let me try measuring the relay instead of the swit...   Sep 16 2009, 10:19 PM
silverteener   I checked on the relay and on 49 I have 12v and on...   Sep 16 2009, 10:37 PM
904svo   I checked on the relay and on 49 I have 12v and o...   Sep 17 2009, 07:56 AM
silverteener   So I get my new relay from Pelican today, not real...   Sep 18 2009, 09:30 PM
904svo   So I get my new relay from Pelican today, not rea...   Sep 18 2009, 09:40 PM
silverteener   I did what you said and the fuse only blew when I ...   Sep 19 2009, 02:03 PM
silverteener   doesn't that red wire run up to the relay? I...   Sep 19 2009, 02:19 PM
silverteener   I cut off the rubber grommet from the relay and al...   Sep 19 2009, 04:17 PM
904svo   Here's the brake down on the wires to the flas...   Sep 19 2009, 06:41 PM
Spoke   It's a real bummer that this issue has been pl...   Sep 19 2009, 10:42 PM
Spoke   Same circuit as previous post except circuit eleme...   Sep 20 2009, 08:07 AM
gothspeed   Do the 4 way flashers work? If not, check you hav...   Sep 21 2009, 03:13 PM
904svo   Do the 4 way flashers work? If not, check you ha...   Sep 21 2009, 04:32 PM
silverteener   I'm still working in the tests. I got to #3, ...   Sep 21 2009, 10:05 PM
Spoke   Did you pull the red wire off of the flasher relay...   Sep 22 2009, 11:30 AM
silverteener   It's working!! :Qarl: :Qarl: Thanks...   Sep 23 2009, 04:36 PM
76-914   :agree: Man, you got some top notch help. How ...   Sep 23 2009, 08:43 PM
- Lo-Fi Version Time is now: 8th July 2025 - 09:33 PM
