WTB =L-Jet Decel air valve 1.8, 1975 #022133551a Bosch still need |
914runnow |
Sep 18 2009, 11:31 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
Used in great cond. or new desired..
this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx |
davesprinkle |
Sep 19 2009, 02:12 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Used in great cond. or new desired.. this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx I don't mean to second-guess your reasons for installing the deccel valve, but you're aware that it doesn't really have an effect on the way the engine runs, right? If you're missing the valve, just plug the vacuum lines. |
914runnow |
Sep 20 2009, 09:46 PM
Used in great cond. or new desired.. this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx I don't mean to second-guess your reasons for installing the deccel valve, but you're aware that it doesn't really have an effect on the way the engine runs, right? If you're missing the valve, just plug the vacuum lines. Concour.....CW Stuff .. Thanx on the info.. |
914runnow |
Sep 25 2009, 05:28 PM
Used in great cond. or new desired.. this is a new post..but pics can be seen. on the other prior request for the 2.0 Vdub.. Thanks Rx I don't mean to second-guess your reasons for installing the deccel valve, but you're aware that it doesn't really have an effect on the way the engine runs, right? If you're missing the valve, just plug the vacuum lines. Concour.....CW Stuff .. Thanx on the info.. (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/confused24.gif) Still Looking.... |
Lo-Fi Version | Time is now: 11th June 2024 - 09:42 AM |
