| VaccaRabite |
Sep 30 2009, 10:24 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
My speedometer works, my odometer does not.
Did I forget to plug something in? I thought it was driven off the speedo cable. Is the gauge just broke? Went on a 60 mile drive tonight (to class and back again). At the start of the trip the odo ended in 60 and the trip counter was at 0000. At the end of the drive nothing had changed. Zach |
| kenshapiro2002 |
Oct 1 2009, 03:07 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Just did mine a few weeks ago. Getting the gauge face off was the toughest part. The odometer works now, but the speedo needle bounces around now (didn't do that before). Doing 60 MPH, the needle bounces between 55 and 65 for example. Hoping it will "heal" itself.
Vacca Rabite Speedo works, Odo doesn't Sep 30 2009, 10:24 PM
Joe Owensby Common problem. A search should turn up detailed... Sep 30 2009, 10:30 PM
jasons I believe there is a "how to" article on... Sep 30 2009, 10:32 PM
Dr Evil We can fix it. I have spare parts and have done th... Sep 30 2009, 11:30 PM
Todd Enlund And if you want to get ambitious while you're ... Oct 1 2009, 02:34 AM
lotus_65 it's from resetting the trip odometer while th... Oct 1 2009, 04:20 AM
zonedoubt
the pelican article talks about deforming the gea... Oct 1 2009, 11:58 AM
lotus_65 well, maybe i should have said it doesn't soun... Oct 1 2009, 05:48 PM
stephenaki
Did ... Oct 1 2009, 05:56 AM
plas76targa Zach - my odometer doesn't work either. Guess ... Oct 1 2009, 06:37 AM
Dr Evil I can fix yours too, Matt :rolleyes: Oct 1 2009, 11:49 AM
gopack I followed the pelican Parts article, and it was a... Oct 1 2009, 11:53 AM
zonedoubt Speedo cable issue? Oct 1 2009, 03:40 PM
kenshapiro2002 It was OK before I went in there. Best lube to use... Oct 1 2009, 04:46 PM
Dr Evil If needles are bouncy, white lithium grease is pro... Oct 1 2009, 04:57 PM
'73-914kid What would you put the litium gease on exactly doc... Oct 1 2009, 05:18 PM
Jerry75914 As mentioned above, there is a great how-to on the... Oct 1 2009, 09:07 PM
Spoke Same thing happened to my 911. Side benefit is I h... Oct 2 2009, 07:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 11th March 2026 - 06:51 AM |
