> Speedo works, Odo doesn't
VaccaRabite
post Sep 30 2009, 10:24 PM
En Garde!
My speedometer works, my odometer does not.
Did I forget to plug something in? I thought it was driven off the speedo cable. Is the gauge just broke?
Went on a 60 mile drive tonight (to class and back again). At the start of the trip the odo ended in 60 and the trip counter was at 0000. At the end of the drive nothing had changed.
Zach
zonedoubt
post Oct 1 2009, 03:40 PM
Canadian Member
Speedo cable issue?
kenshapiro2002
post Oct 1 2009, 04:46 PM
It was OK before I went in there. Best lube to use?
QUOTE(zonedoubt @ Oct 1 2009, 05:40 PM) *
Speedo cable issue?
Vacca Rabite   Speedo works, Odo doesn't   Sep 30 2009, 10:24 PM
Joe Owensby   Common problem. A search should turn up detailed...   Sep 30 2009, 10:30 PM
jasons   I believe there is a "how to" article on...   Sep 30 2009, 10:32 PM
Dr Evil   We can fix it. I have spare parts and have done th...   Sep 30 2009, 11:30 PM
Todd Enlund   And if you want to get ambitious while you're ...   Oct 1 2009, 02:34 AM
lotus_65   it's from resetting the trip odometer while th...   Oct 1 2009, 04:20 AM
zonedoubt   the pelican article talks about deforming the gea...   Oct 1 2009, 11:58 AM
lotus_65   well, maybe i should have said it doesn't soun...   Oct 1 2009, 05:48 PM
stephenaki   My speedometer works, my odometer does not. Did ...   Oct 1 2009, 05:56 AM
plas76targa   Zach - my odometer doesn't work either. Guess ...   Oct 1 2009, 06:37 AM
Dr Evil   I can fix yours too, Matt :rolleyes:   Oct 1 2009, 11:49 AM
gopack   I followed the pelican Parts article, and it was a...   Oct 1 2009, 11:53 AM
kenshapiro2002   Just did mine a few weeks ago. Getting the gauge f...   Oct 1 2009, 03:07 PM
zonedoubt   Speedo cable issue?   Oct 1 2009, 03:40 PM
kenshapiro2002   It was OK before I went in there. Best lube to use...   Oct 1 2009, 04:46 PM
Dr Evil   If needles are bouncy, white lithium grease is pro...   Oct 1 2009, 04:57 PM
'73-914kid   What would you put the litium gease on exactly doc...   Oct 1 2009, 05:18 PM
Jerry75914   As mentioned above, there is a great how-to on the...   Oct 1 2009, 09:07 PM
Spoke   Same thing happened to my 911. Side benefit is I h...   Oct 2 2009, 07:38 AM
- Lo-Fi Version Time is now: 11th March 2026 - 06:51 AM
