| ME733 |
Jul 5 2009, 12:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
You have asked about the fuchs which came on my 914 S....here goes...the O.E.M. spare rim is dated 8-72...and so are all the others.....and they are part#...914.361.011.00 .They look different in /on the backside than THE PHOTOGRAPH with notes you have shown......as a point of intrest the spare RIM and ALL the four on the ground are identical in every way...EXCEPT the four on the ground have a Painted BACKGROUND.....and after looking closely with a magnifing glass its obvious they are painted...and not quite dead flat black....they are Not anodized....the spare tire is an original tire ..DUNLOP 165 hr 15....looks like it and the rim have NEVER been used...the rim is clean and perfect (both sides and the tire has full tread....and is not dry rotted.(cracks showing in sidewalls)..However,.I would never consider using it obviously. (IMG:style_emoticons/default/bye1.gif)
| ME733 |
Oct 4 2009, 08:43 PM
(IMG:style_emoticons/default/popcorn[1].gif) TOM...the ...FUCHS forged wheels..(just one orig. set)..is machined with the clearances I described......The "MAHLE" wheels....(both sets)... END with a ..00...number...and are MACHINED (factory machining).. to FIT ..."HUB CENTRIC"..HUBS...with the .002ths -to -.004ths clearance..between the inside of the wheel ...and outside of the "HUB".....Does this help?...murray (IMG:style_emoticons/default/popcorn[1].gif)
| Tom_T |
Oct 4 2009, 10:00 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
(IMG:style_emoticons/default/popcorn[1].gif) TOM...the ...FUCHS forged wheels..(just one orig. set)..is machined with the clearances I described......The "MAHLE" wheels....(both sets)... END with a ..00...number...and are MACHINED (factory machining).. to FIT ..."HUB CENTRIC"..HUBS...with the .002ths -to -.004ths clearance..between the inside of the wheel ...and outside of the "HUB".....Does this help?...murray (IMG:style_emoticons/default/popcorn[1].gif) Got it on the Mahles Murry. Are the Fuchs -00 or -01 P.N.s?? (IMG:style_emoticons/default/confused24.gif) I would guess that there is really no way to know for sure, if after-the-fact machining on any -00 wheels is by the "factory" (Fuchs, Mahle, Pedrini, etc.), or if it was done by another machine shop. However, my guess is that it would be cost prohibitive to ship 1.5x to Europe & back (1st with car, then a round trip) for a set of wheels, just to have them machined for the self-centering hub's lips, so that they would most likely have been done by an aftermarket fix here in the US/CAN, or whichever country of first shipment/sale of the car in question. I know that I've seen ads online where the seller states that they had the set of "xxx" -00 wheels for sale, machined for the hub-centric hub fitment. BTW - the non-hub-centric or non-self-centering hubs on the 914/4s, VWs & similar hub cars were not lug-centric - since there are no studs on which to "center" the wheels! (IMG:style_emoticons/default/sad.gif) My method was to sit cross-legged, prop the tire/wheel on my legs & forhead while guiding the lug bolt in an upper hole to get it centered - what a pain in the A!!!! (IMG:style_emoticons/default/dry.gif) Fortunately today they sell the brass centering studs to ease the process. (IMG:style_emoticons/default/smile.gif) |
ME733 more about Fuchs Jul 5 2009, 12:00 PM
Tom_T Thanx - great info ME733,
Your info proves that t... Jul 5 2009, 04:08 PM
ME733 Tom...this is murray.,,I found your questions intr... Jul 5 2009, 10:55 PM
ME733
Tom...this is murray.,,I found your questions int... Sep 21 2009, 09:29 AM
Tom_T
Tom...this is murray.,,I found your questions in... Sep 21 2009, 02:13 PM
Pat Garvey Two things here, and the post will be moved to the... Jul 6 2009, 08:17 PM
Tom_T BTW Pat -
Because the early hubs were flat ... Jul 6 2009, 10:34 PM
McMark
Anodizing in an electrical process involving cath... Jul 7 2009, 07:12 PM
RobW
Anodizing in an electrical process involving cat... Jul 7 2009, 08:50 PM
Pat Garvey
Anodizing in an electrical process involving ca... Jul 7 2009, 09:11 PM
Tom_T
Anodizing in an electrical process involving cat... Jul 7 2009, 09:49 PM
Tom_T
Anodizing in an electrical process involving cat... Jul 7 2009, 10:21 PM
orthobiz
So McMark - on those 2L alloys - did they color ... Jul 11 2009, 10:20 PM
McMark So McMark - on those 2L alloys - did they color th... Jul 22 2009, 04:22 PM
Tom_T
So McMark - on those 2L alloys - did they color t... Jul 22 2009, 04:39 PM
Bleyseng
[quote name='McMark' post='1194209' date='Jul 22 ... Sep 21 2009, 10:35 PM
Tom_T
[quote name='McMark' post='1194209' date='Jul 22... Sep 21 2009, 10:52 PM
Tom_T Listing of several wheel refinishers on both coast... Jul 7 2009, 10:09 PM
Tom_T I suppose the background could be more of a raw un... Jul 11 2009, 11:30 PM
6freak new Fuchs now available through Porsche ...$1... Jul 11 2009, 11:37 PM
Tom_T
new Fuchs now available through Porsche ...... Jul 11 2009, 11:46 PM
6freak
new Fuchs now available through Porsche ...... Jul 12 2009, 12:18 AM
Tom_T
new Fuchs now available through Porsche ...... Jul 12 2009, 12:11 PM
6freak Talk`n bout the 5 lugs.....From Porsche Design... Jul 13 2009, 09:35 AM
Tom_T
Talk`n bout the 5 lugs.....From Porsche Desig... Jul 14 2009, 12:55 AM
6freak If I keep buy`n fancy stuff I`ll never get... Jul 14 2009, 11:06 AM
ME733 :popcorn: Tom...I did ask an expert about the ... Sep 21 2009, 09:20 PM
Tom_T
:popcorn: Tom...I did ask an expert about the ... Sep 21 2009, 10:05 PM
Pat Garvey
:popcorn: Tom...I did ask an expert about the ... Sep 22 2009, 07:32 PM
Bleyseng I have used Wurth's silver as its a close matc... Sep 23 2009, 08:17 AM
ME733 :popcorn: George H at A.A. has the exact wurth col... Sep 23 2009, 11:50 PM
Tom_T
:popcorn: George H at A.A. has the exact wurth co... Sep 26 2009, 06:30 PM
davep In my experience there were 3 front brake rotors u... Sep 25 2009, 09:02 AM
ME733 :popcorn: Hello davep....Intresting obversavions i... Sep 25 2009, 08:26 PM
Tom_T Yes Murray, the Fuchs 2L were listed as "Forg... Sep 26 2009, 01:46 PM
ME733 :popcorn: TOM, ..Is this of any intrest?...my O.E.... Oct 2 2009, 12:13 PM
Tom_T
:popcorn: TOM, ..Is this of any intrest?...my O.E... Oct 2 2009, 03:43 PM
ME733 :popcorn: ...YES TOM this information does help...... Oct 3 2009, 08:03 AM
Tom_T
:popcorn: ...YES TOM this information does help..... Oct 3 2009, 10:56 AM
Jeff Bowlsby The correct link for the recall info is now: http... Oct 4 2009, 10:19 AM
Tom_T
The correct link for the recall info is now: htt... Oct 4 2009, 10:58 AM
Jeff Bowlsby Hi Tom, I did post the website links update a wee... Oct 5 2009, 02:49 PM
Tom_T
Hi Tom, I did post the website links update a we... Oct 5 2009, 03:54 PM
ME733 :popcorn: ...TOM...So in my wonderment ..about WHY... Oct 4 2009, 11:52 AM
Tom_T
:popcorn: ...TOM...So in my wonderment ..about WH... Oct 4 2009, 07:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:57 PM |
