Nor.Cal.914 |
1975 914 3.0SC ![]() ![]() ![]() Group: Members Posts: 1,062 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None ![]() |
My steering column had a bunch of slop in it so I decided it was time to replace the bearing. I bought the bearing and the repair sleeve from Pelican. If I am replacing the bearing, is it necessary to put in that sleeve? Or is the sleeve just a temporary fix for when the bearing gets slightly sloppy? Also, how does the ignition assembly come apart from the steering column on a '75? I have the steering column apart already and the metal sleeve that houses the ignition and the column bearing is out of the plastic portion covering it. I am now trying to figure out how the ignition assembly comes out of that metal sleeve! How does the ignition come apart from that sleeve? Please let me know. Thanks!
-Chris |
Lo-Fi Version | Time is now: 5th July 2025 - 10:10 PM |
