> Ignition Disassembly and Steering Column, Bearing Replacement
Nor.Cal.914
post Oct 8 2009, 08:13 PM
1975 914 3.0SC
My steering column had a bunch of slop in it so I decided it was time to replace the bearing. I bought the bearing and the repair sleeve from Pelican. If I am replacing the bearing, is it necessary to put in that sleeve? Or is the sleeve just a temporary fix for when the bearing gets slightly sloppy? Also, how does the ignition assembly come apart from the steering column on a '75? I have the steering column apart already and the metal sleeve that houses the ignition and the column bearing is out of the plastic portion covering it. I am now trying to figure out how the ignition assembly comes out of that metal sleeve! How does the ignition come apart from that sleeve? Please let me know. Thanks!
-Chris
Cap'n Krusty
post Oct 8 2009, 10:37 PM
Cap'n Krusty
The insert is a PERMANENT fix, you don't need the bearing unless it's trashed. The Cap'n
- Lo-Fi Version Time is now: 5th July 2025 - 09:29 PM
