| ClayPerrine |
Oct 11 2009, 10:06 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
From the Steering Wheel Thread:
Not a real six.. just the dash frame out of a totalled real six. I had to build the column up from scratch. Thanks for the compliment though. (IMG:style_emoticons/default/biggrin.gif) It's a good looking dash, & I'm still hoping you find the write-up on how you did that column..... (IMG:style_emoticons/default/dry.gif) Ok.. I found the pictures. Not really too detailed, as I got involved in making it instead of taking pictures. Start with a 4 cylinder column. Remove the mounting plate from it. Pict is of the leftover column tube. (IMG:style_emoticons/default/sawzall-smiley.gif) Now you have just the column mounting plate. Remove the mounts from the 911 column, saving the tube. (IMG:style_emoticons/default/sawzall-smiley.gif) ![]() Weld the 4 cylinder mount to the 911 column. (IMG:style_emoticons/default/welder.gif) You should end up with this. Now you can put the column back together. I don't know about a car with a stock 3 gauge dash, but with the 911 style dash I had to trim the front edge of the top clamshell to get it to clear the gauge assembly. Now on to the dash frame. I got a rusted out six dash from a guy who totalled his six. Here are both the 4 cylinder dash and the six dash together. The four dash is from a 73. To use a six style column, you have to modify the dash to hold the ignition lock. I had the six dash, so I used it. The six dash doesn't have the holes for the air vents, and I have a future use for them (Air Conditioning) so I chose to keep them. This entailed cutting a hole in the left side of the dash for the vent. I then took the dash frame and cut the glovebox end off because there is no hole for the vent on the right side. I spliced in the end from the 4 cylinder dash to add the hole. You have to remember that the early no vent glovebox is an inch wider than the 73 and later glovebox. I mounted the glovebox door from the 73 in the frame to hold it in place while I tack welded the frame parts together. Finished dash.... The conversion also meant that I lost the location for one switch to the left of the column. So I moved the hazard switch to the right of the column. If someone wanted to make a copy of the key location for a six column that could be welded into a 4 cylinder dash it would make this much easier to do. I am not a body man so I can't do something like this. I know this is short on picutres. If someone wants one of these done, and can supply the parts. I will be glad to do a second one. But you have to come take pictures while I build it. (IMG:style_emoticons/default/biggrin.gif) |
| rick 918-S |
Oct 11 2009, 10:20 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,243 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Clay, Very nice write up. If you take and cover the key switch stamping with masking tape, lightly apply some wax to the tape and make a fibre glas plug of the stamping and send it to me I think I could make some out of sheet metal. (IMG:style_emoticons/default/smash.gif) |
ClayPerrine Six Column Conversion Oct 11 2009, 10:06 AM
type47fan [quote name='rick 918-S' post='1224575' date=... Oct 11 2009, 05:54 PM
rick 918-S
[quote name='rick 918-S' post='1224575' date... Oct 11 2009, 06:01 PM
bcheney I think this should go over into the Lapuwali clas... Oct 11 2009, 08:24 PM
Todd Enlund
Clay,
Very nice write up.
If you take and cov... Oct 11 2009, 11:50 PM
sixnotfour I used the -4 cheap switch and made it look like ... Oct 11 2009, 11:59 PM
markb :Qarl: Thanks Clay!
I have the switch part fro... Oct 12 2009, 12:53 AM
bandjoey Definitely a classic entry Clay! Good write u... Oct 14 2009, 11:53 AM
70Sixter Nice work. I'd always been told this couldn... Oct 14 2009, 03:16 PM
ClayPerrine
Nice work. I'd always been told this couldn... Oct 15 2009, 07:57 AM
type47fan
The perfect companion to this thread would be a... Oct 15 2009, 09:14 PM
Jgilliam914 After scouring the archives I have found this one ... Jan 24 2013, 05:16 PM
edwin Anyone have a ball park figure of what the parts s... Jan 24 2013, 07:23 PM
Jgilliam914 I did some looking before I got all my parts. The ... Jan 24 2013, 09:43 PM
jm993rs Very good idea !!! Jan 25 2013, 03:27 PM
Harpo Good afternoon
To those of you that have blazed t... Apr 10 2013, 04:32 PM
Jgilliam914 I do not think so. You will have to convert a 911 ... Apr 10 2013, 06:04 PM
porsche913b_sp So is there a particular year for the donor clam s... Apr 11 2013, 11:50 PM
So is there a particular year for the donor clam ... Apr 12 2013, 03:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 08:04 PM |
