> Six Column Conversion, Make your car look like a real six inside....
ClayPerrine
post Oct 11 2009, 10:06 AM
From the Steering Wheel Thread:
QUOTE(markb @ Oct 9 2009, 08:59 AM) *
QUOTE(ClayPerrine @ Oct 8 2009, 11:54 PM) *
Not a real six.. just the dash frame out of a totalled real six. I had to build the column up from scratch.
Thanks for the compliment though. (IMG:style_emoticons/default/biggrin.gif)
It's a good looking dash, & I'm still hoping you find the write-up on how you did that column..... (IMG:style_emoticons/default/dry.gif)
Ok.. I found the pictures. Not really too detailed, as I got involved in making it instead of taking pictures.
Start with a 4 cylinder column. Remove the mounting plate from it.
Pict is of the leftover column tube. (IMG:style_emoticons/default/sawzall-smiley.gif)
Now you have just the column mounting plate.
Remove the mounts from the 911 column, saving the tube. (IMG:style_emoticons/default/sawzall-smiley.gif)
Weld the 4 cylinder mount to the 911 column. (IMG:style_emoticons/default/welder.gif) You should end up with this.
Now you can put the column back together. I don't know about a car with a stock 3 gauge dash, but with the 911 style dash I had to trim the front edge of the top clamshell to get it to clear the gauge assembly.
Now on to the dash frame.
I got a rusted out six dash from a guy who totalled his six.
Here are both the 4 cylinder dash and the six dash together.
The four dash is from a 73. To use a six style column, you have to modify the dash to hold the ignition lock. I had the six dash, so I used it. The six dash doesn't have the holes for the air vents, and I have a future use for them (Air Conditioning) so I chose to keep them. This entailed cutting a hole in the left side of the dash for the vent.
I then took the dash frame and cut the glovebox end off because there is no hole for the vent on the right side. I spliced in the end from the 4 cylinder dash to add the hole. You have to remember that the early no vent glovebox is an inch wider than the 73 and later glovebox. I mounted the glovebox door from the 73 in the frame to hold it in place while I tack welded the frame parts together.
Finished dash....
The conversion also meant that I lost the location for one switch to the left of the column. So I moved the hazard switch to the right of the column.
If someone wanted to make a copy of the key location for a six column that could be welded into a 4 cylinder dash it would make this much easier to do. I am not a body man so I can't do something like this.
I know this is short on picutres. If someone wants one of these done, and can supply the parts. I will be glad to do a second one. But you have to come take pictures while I build it. (IMG:style_emoticons/default/biggrin.gif)
rick 918-S
post Oct 11 2009, 10:20 AM
Hey nice rack! -Celette
Clay,
Very nice write up.
If you take and cover the key switch stamping with masking tape, lightly apply some wax to the tape and make a fibre glas plug of the stamping and send it to me I think I could make some out of sheet metal. (IMG:style_emoticons/default/smash.gif)
type47fan
post Oct 11 2009, 05:54 PM
It Looks Better In Person. . .
QUOTE(rick 918-S @ Oct 11 2009, 08:20 AM) *
Clay,
Very nice write up.
Rick,
I did this with a -6 dash I had. PM me your address and I'll send you the plug and a couple of tin foil impressions I made of the key switch depression.
Thanks,
ClayPerrine   Six Column Conversion   Oct 11 2009, 10:06 AM
rick 918-S   Clay, Very nice write up. If you take and cove...   Oct 11 2009, 10:20 AM
type47fan   [quote name='rick 918-S' post='1224575' date=...   Oct 11 2009, 05:54 PM
rick 918-S   [quote name='rick 918-S' post='1224575' date...   Oct 11 2009, 06:01 PM
bcheney   I think this should go over into the Lapuwali clas...   Oct 11 2009, 08:24 PM
Todd Enlund   Clay, Very nice write up. If you take and cov...   Oct 11 2009, 11:50 PM
sixnotfour   I used the -4 cheap switch and made it look like ...   Oct 11 2009, 11:59 PM
markb   :Qarl: Thanks Clay! I have the switch part fro...   Oct 12 2009, 12:53 AM
bandjoey   Definitely a classic entry Clay! Good write u...   Oct 14 2009, 11:53 AM
70Sixter   Nice work. I'd always been told this couldn...   Oct 14 2009, 03:16 PM
ClayPerrine   Nice work. I'd always been told this couldn...   Oct 15 2009, 07:57 AM
type47fan   The perfect companion to this thread would be a...   Oct 15 2009, 09:14 PM
Jgilliam914   After scouring the archives I have found this one ...   Jan 24 2013, 05:16 PM
edwin   Anyone have a ball park figure of what the parts s...   Jan 24 2013, 07:23 PM
Jgilliam914   I did some looking before I got all my parts. The ...   Jan 24 2013, 09:43 PM
jm993rs   Very good idea !!!   Jan 25 2013, 03:27 PM
Harpo   Good afternoon To those of you that have blazed t...   Apr 10 2013, 04:32 PM
Jgilliam914   I do not think so. You will have to convert a 911 ...   Apr 10 2013, 06:04 PM
porsche913b_sp   So is there a particular year for the donor clam s...   Apr 11 2013, 11:50 PM
SirAndy   So is there a particular year for the donor clam ...   Apr 12 2013, 03:30 AM
- Lo-Fi Version Time is now: 15th April 2026 - 08:05 PM
