> Dr. Evil may have given me a disease!, Never under estimate the power of the dark side.
Mark Henry
post Oct 7 2009, 12:36 PM
that's what I do!
In one weekend the Doc totally demistfied the 901 transmission and manual transmissions in general.
Because the only transmission I've ever taken a peek at was the aircooled VW, I've been scared of tranny's like a little girly-man.
I'm not an expert yet, but I hope Mike would say I'm compitaint.
I have 2 transmissions built from the clinic, plus enough spares to build a another 901 if I had another core.
In this pic, if you look at top 1/3, center, you can see (on the pegboard hook) dog teeth, 1st sliders, sider and a few bands. Nice score.
2nd pic is the 911 901 that the Doc built as a demonstrator, same thing as a 914, just a bit different on the nose cone and selector.
tracks914
post Oct 16 2009, 03:09 PM
Canadian Member
Thanks for the reply Mike.
I do not have the jig but I did put a scribe mark on each shaft before I removed each shift fork. The fork went back on in the same position (linear) as they came off. As noted before, I just had one of them slightly rotated and this caused some binding in the shifting.
Both Haynes and factory manuals said to remove the drive gear (small) from the the shaft before removing the gear assemblies from the intermediate plate. This is why I did it. The gear was tight to remove but it didn't "pick up" and came off smoothly, just tight. When I put it back on, I could easily return it to it's original position with the nut and a 3/8" ratchet. (To remove it again I would still need a puller as I don't think I could pry it off without one)
I guess I could have removed the pinion shaft without removing the #1 (small) first gear but I wasn't keen on tapping the shaft out with the gears still slightly engaged. Now that I see how the bearing on the pinion shaft comes apart I guess I didn't need to remove the drive shaft. This is only the second time I have done this so live and learn.
If you feel that returning the shift forks to their original postion might not be "good enough" let me know and I will take it out of the car and align them properly.
Tx
Mark Henry   Dr. Evil may have given me a disease!   Oct 7 2009, 12:36 PM
Mark Henry   This is my new undertaking. Ooooooohhhhh.....that...   Oct 7 2009, 12:37 PM
Mark Henry   Man do I have spares in my stash, this is going to...   Oct 7 2009, 12:39 PM
tracks914   Man do I have spares in my stash, this is going t...   Oct 8 2009, 12:04 PM
Mark Henry   Man do I have spares in my stash, this is going ...   Oct 15 2009, 09:27 PM
Mark Henry   This stuff I had (before I grew a pair) bearings ...   Oct 7 2009, 12:44 PM
Dr Evil   Yer welcome, eh!   Oct 7 2009, 01:08 PM
r_towle   What has been learned cannot be unlearned. Rich   Oct 7 2009, 01:12 PM
Mark Henry   What has been learned cannot be unlearned. Rich ...   Oct 7 2009, 01:19 PM
oldschool   What has been learned cannot be unlearned. Rich...   Oct 18 2009, 01:32 AM
Mark Henry   [quote name='Mark Henry' post='1223102' date='Oct...   Oct 18 2009, 09:01 AM
oldschool   [quote name='Mark Henry' post='1223102' date='Oc...   Oct 18 2009, 06:24 PM
Dr Evil   Why not use one of the parts boxes? It sounds like...   Oct 7 2009, 01:41 PM
Mark Henry   It sounds like your home schooling endeavor is g...   Oct 7 2009, 02:13 PM
tat2dphreak   so, if one has never attempted a transmission rebu...   Oct 7 2009, 01:45 PM
Mark Henry   so, if one has never attempted a transmission reb...   Oct 7 2009, 01:55 PM
SGB   yer just obsessed! :) Nobody here can relate...   Oct 7 2009, 01:50 PM
tat2dphreak   yea, I was planning on picking up an extra transmi...   Oct 7 2009, 02:22 PM
Mark Henry   yea, I was planning on picking up an extra transm...   Oct 7 2009, 02:45 PM
tat2dphreak   ok, I understand. or at least I'll nod and gri...   Oct 7 2009, 02:56 PM
Mark Henry   BTW please bear in mind I'm mechanically incli...   Oct 7 2009, 02:59 PM
swl   BTW please bear in mind I'm mechanically incl...   Oct 7 2009, 06:46 PM
balljoint   BTW please bear in mind I'm mechanically inc...   Oct 8 2009, 09:46 AM
davep   Yeah, even an old fart like me learned a lot. I...   Oct 7 2009, 03:20 PM
crash914   is that a Nickie just sitting on the shelf in the ...   Oct 7 2009, 04:20 PM
degreeoff   is that a Nickie just sitting on the shelf in the...   Oct 7 2009, 05:05 PM
Dr Evil   Its a Nickie   Oct 7 2009, 06:43 PM
davep   Those were type 1 synchro rings. A little less val...   Oct 9 2009, 06:56 PM
tracks914   I'm off this weekend, I pulled my tranny this ...   Oct 9 2009, 07:40 PM
Dr Evil   Post pics, we can all dx it for you.   Oct 9 2009, 09:24 PM
tracks914   Took it apart. All looked pretty good. Changed 1st...   Oct 14 2009, 09:33 PM
Dr Evil   :blink:   Oct 15 2009, 06:17 PM
tracks914   :blink: I re-worded the post, does it make any s...   Oct 16 2009, 12:21 PM
davep   Oh yeah! got my P284 tool for removing/install...   Oct 15 2009, 06:37 PM
davep   Was that diff tool VW385? If so it probably will. ...   Oct 16 2009, 07:00 AM
Mark Henry   Was that diff tool VW385? If so it probably will....   Oct 17 2009, 08:06 AM
Dr Evil   The blinking face was for the adjustment. Do you h...   Oct 16 2009, 12:46 PM
tracks914   Thanks for the reply Mike. I do not have the jig b...   Oct 16 2009, 03:09 PM
Dr Evil   Doug, other than aligning the marks, did you chec...   Oct 16 2009, 06:09 PM
tracks914   "index of the selector section of the rods...   Oct 16 2009, 06:42 PM
balljoint   "index of the selector section of the rods...   Oct 16 2009, 08:16 PM
Dr Evil   The part of the rods that interfaces with the shif...   Oct 16 2009, 09:33 PM
davep   Why not use a 911 box then? A lot less case work a...   Oct 17 2009, 06:32 PM
Dr Evil   You can convert a tail shift to a 911 style with e...   Oct 17 2009, 06:42 PM
tracks914   :driving: Just came back from a test drive. :drivi...   Oct 18 2009, 03:00 PM
Mark Henry   Ohhhhhh.....Doug lives in Timmins....I see..... :...   Oct 18 2009, 05:39 PM
tracks914   Ohhhhhh.....Doug lives in Timmins....I see..... ...   Oct 20 2009, 08:39 PM
Dr Evil   You type with an accent, Jamie ;)   Oct 18 2009, 10:57 PM
oldschool   You type with an accent, Jamie ;) see! i me...   Oct 18 2009, 10:59 PM
JazonJJordan   :popcorn: ya'll gots sum of dem ak'sents t...   Oct 18 2009, 11:11 PM
pete-stevers   hey doc did you get a list of dem tools i waz tink...   Oct 19 2009, 12:08 AM
Dr Evil   What you talk'in bout, Pete?   Oct 19 2009, 09:50 AM
Mark Henry   The sickness continues...... http://www.914world....   Oct 20 2009, 09:34 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:59 PM
