Parking Brake Light Not Going Out |
kenshapiro2002 |
Oct 21 2009, 10:06 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Well...it diminishes by about 50%. What might be up with that? The light wasn't working at all when I got the car. The switch, under the handle needed some cleaning and lube, and then operated prefectly up until my drive today. Brake seemed to be all the way released since she rolled easily on a slight incline, but the light only dimmed...didn't go off.
swl |
Oct 22 2009, 05:24 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
that is a switch to ground. If you have a nick or smush in the electrical lead it will leak to ground give you partial on. Spirited driving has moved whatever was pinching it. Betcha if you follow the cable you'll find it pinched somewhere - probably in the seat rail.
kenshapiro2002 |
Oct 22 2009, 05:25 PM
Probably right as it's now intermittent.
that is a switch to ground. If you have a nick or smush in the electrical lead it will leak to ground give you partial on. Spirited driving has moved whatever was pinching it. Betcha if you follow the cable you'll find it pinched somewhere - probably in the seat rail. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:13 PM |
