Glass fuel filters- What are your thoughts?, Yea or Ney? |
URY914 |
Oct 23 2009, 02:23 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,106 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
These things have been around for a long time. VW guys have been using them forever. Advanages being you can see the junk thru the glass and you can clean and reuse them. They are cheap at about $8.00.
Down side is they are glass and can break. IIRC they are not SCCA legal for this reason. If you use them do you install them in the engine compartment where it is less likely to be hit by a rock and break. But when they do break they allow gas to cover the engine. Or do you mount them up under the engine shelf out of the way so when they break they dump gas on the road? Has anyone ever heard of one breaking? I have one for my street car and don't know if I should install it or get a typical OEM plastic/steel body one from my FLAPS. What say you??? Attached image(s) |
kenshapiro2002 |
Oct 24 2009, 12:00 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Confused (not the first time)...how are his clamps different form the second one in your recommended example?
Cevan |
Oct 24 2009, 10:25 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
kenshapiro2002 |
Oct 24 2009, 10:54 PM
That would make sense, but he said "I would also recommend ditching those clamps you were using and switch to either of these since these styles won't cut into the hose and cause leaks. . ."
Confused (not the first time)...how are his clamps different form the second one in your recommended example? I think he means use the first one (FI style clamp) and not the second one, which will cut into the hose. |
Lo-Fi Version | Time is now: 16th June 2024 - 03:25 AM |
