drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I'm replacing my Renegade/Chrysler BB pump, since it locked up last night. I didn't here any noise at all ? The engine does make a bit of noise but you would think there would be some warning. Nope ! Maybe something broke off and jammed up the impeller etc. The pump just locked up and melted the drive belt. My question is I have been running a standard pump and decided to get a high volume unit. My assumption is the quality is better than my last one and with A/C it might perform better moving more water. I guess with more pressure comes it own set of issues. One thought is the belt was too tight, and that's a good bet. I'm not running a Thermostat but am running a minor restriction in the thermostat housing, which I think I should remove.. ? Any one have any input here. (IMG:style_emoticons/default/type.gif) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
How many do you want?
Stamped steel Cast iron. Aluminium body Cast iron body |
drive-ability |
How many do you want? Stamped steel Cast iron. Aluminum body Cast iron body I used a aluminum 6 blade stamped steel unit and it worked well until it blew apart. 6 blade stamped & Cast impeller, do they flow different ? Thanks Bob for the phone number I wonder if I could use the 6 blade stamped unit and weld on a anti-cavitation plate ? Can't see how that would be hard, but would it dumb down the flow ? |
Lo-Fi Version | Time is now: 13th June 2024 - 02:50 AM |
