914 Water pump, Yes a SBC |
drive-ability |
Oct 20 2009, 01:51 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I'm replacing my Renegade/Chrysler BB pump, since it locked up last night. I didn't here any noise at all ? The engine does make a bit of noise but you would think there would be some warning. Nope ! Maybe something broke off and jammed up the impeller etc. The pump just locked up and melted the drive belt. My question is I have been running a standard pump and decided to get a high volume unit. My assumption is the quality is better than my last one and with A/C it might perform better moving more water. I guess with more pressure comes it own set of issues. One thought is the belt was too tight, and that's a good bet. I'm not running a Thermostat but am running a minor restriction in the thermostat housing, which I think I should remove.. ? Any one have any input here. (IMG:style_emoticons/default/type.gif) |
drive-ability |
Oct 29 2009, 07:07 PM
(IMG:style_emoticons/default/clap56.gif) Thank You, I now understand there was allot of R&D done a long time ago. Surely there's more going on here then you might expect. I think I can use this pump for a while because it cooler here and I'm not running over 200 at any time. I would like to get the 6 blade unit installed soon. Thanks (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 12th June 2024 - 07:50 PM |
