| tradisrad |
Nov 1 2009, 08:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
All exterior lights work properly, but both the dash lights (left and right turn signal) go on when I use my turn signal. I am expecting the left arrow to flash for a left turn and the right arrow for a right turn, but both arrows flash all the time. the car is a 1970. I think I cleaned all the ground points.
Is this a common problem? What is the fix? thanks -Rob |
| underthetire |
Nov 1 2009, 10:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I have the same issue with mine. Someone here said bad ground. Groundloop through a bulb will cause this. I to have not done anything about it either.
tradisrad Both turn signal dash lights Nov 1 2009, 08:44 PM
flipb
All exterior lights work properly, but both the d... Nov 1 2009, 08:46 PM
904svo Make sure all the bulbs are the correct ones, if y... Nov 1 2009, 09:42 PM
orange914
I have the same issue with mine. Someone here sai... Nov 1 2009, 11:10 PM
tradisrad Is it a good thing that I am not alone? Don't ... Nov 1 2009, 10:13 PM
tat2dphreak shit, I thought it was the "way it was".... Nov 1 2009, 11:12 PM
john rogers Some 914s had but one light in the tach and some h... Nov 1 2009, 11:27 PM
jetboy Let us know if replacing the relay is a fix. Mine ... Nov 2 2009, 04:46 AM
tradisrad What rust? Well I do have a very small amount in t... Nov 2 2009, 09:08 AM
rhcb914 I have a 70 and mine has a similar issue. Turn on... Nov 2 2009, 09:23 AM
type47 If I recall, this may be the way it operates; both... Nov 2 2009, 09:28 AM
If I recall, this may be the way it operates; bot... Nov 2 2009, 03:16 PM
underthetire
If I recall, this may be the way it operates; bo... Nov 2 2009, 03:38 PM
orange914
Yes. Sort of. Early cars should have the indicato... Nov 2 2009, 07:26 PM
flipb
[quote name='montoya 73 2.0' post='1223878' date=... Nov 2 2009, 09:52 AM
flipb And since I like pictures, here are the two leads ... Nov 2 2009, 10:18 AM
tat2dphreak hmm. I didn't care before, but now I must look... Nov 2 2009, 10:33 AM
plas76targa FWIW - my 72 blinks similar to above - left flashe... Nov 2 2009, 12:25 PM
Phoenix-MN
FWIW - my 72 blinks similar to above - left flash... Nov 2 2009, 12:44 PM
SGB I had the both indicators flashing thing for 15 ye... Nov 2 2009, 03:02 PM
ConeDodger I am glad Andy cleared that up... I thought it was... Nov 2 2009, 03:55 PM
underthetire
I am glad Andy cleared that up... I thought it wa... Nov 2 2009, 04:00 PM
wobbletop Mine both flash at once. Always thought it was the... Nov 2 2009, 03:56 PM
Spoke Mine both flashed on my 71.
Problem was not groun... Nov 2 2009, 04:09 PM
Rod Amazing how many people have this problem!
..... Nov 2 2009, 04:31 PM
kenshapiro2002 I went through all of this about a month ago...che... Nov 2 2009, 06:44 PM
astronomerdave
All exterior lights work properly, but both the d... Nov 8 2009, 02:11 AM
tradisrad
All exterior lights work properly, but both the ... Nov 8 2009, 01:13 PM
underthetire 73, late. independant bulbs. Nov 8 2009, 10:33 AM
tradisrad I swaped out my trun signal relay and they light u... Nov 14 2009, 04:24 PM
kenshapiro2002 One prong.
I swaped out my trun signal relay an... Nov 14 2009, 06:18 PM
Toast Both of mine flash ONLY when I am applying the bra... Nov 14 2009, 07:48 PM
kenshapiro2002 Betting a new flasher relay would cure it...borrow... Nov 14 2009, 09:07 PM
celluloid3 I have the same problem...
Both of mine flash ON... Dec 13 2009, 01:30 AM
Richncherie For the last few days the green left/right turn si... Aug 24 2020, 11:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 04:48 PM |
