| tradisrad |
Nov 1 2009, 08:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
All exterior lights work properly, but both the dash lights (left and right turn signal) go on when I use my turn signal. I am expecting the left arrow to flash for a left turn and the right arrow for a right turn, but both arrows flash all the time. the car is a 1970. I think I cleaned all the ground points.
Is this a common problem? What is the fix? thanks -Rob |
| tradisrad |
Nov 1 2009, 10:13 PM
Is it a good thing that I am not alone? Don't think so.
My inital thought was a burnt out bulb, but all 4 corners work. Am I correct to say that the side markers do not act as turn signals? I've got extra relays so I'll try that first. My car has been off of the road for 25+ years and this is my main electrical problem, so I think I'm doing ok. If I get to it soon I'll post my results. I may get to it after I put the trash out tonight or else it's later in the week. |
tradisrad Both turn signal dash lights Nov 1 2009, 08:44 PM
flipb
All exterior lights work properly, but both the d... Nov 1 2009, 08:46 PM
904svo Make sure all the bulbs are the correct ones, if y... Nov 1 2009, 09:42 PM
underthetire I have the same issue with mine. Someone here said... Nov 1 2009, 10:08 PM
orange914
I have the same issue with mine. Someone here sai... Nov 1 2009, 11:10 PM
tat2dphreak shit, I thought it was the "way it was".... Nov 1 2009, 11:12 PM
john rogers Some 914s had but one light in the tach and some h... Nov 1 2009, 11:27 PM
jetboy Let us know if replacing the relay is a fix. Mine ... Nov 2 2009, 04:46 AM
tradisrad What rust? Well I do have a very small amount in t... Nov 2 2009, 09:08 AM
rhcb914 I have a 70 and mine has a similar issue. Turn on... Nov 2 2009, 09:23 AM
type47 If I recall, this may be the way it operates; both... Nov 2 2009, 09:28 AM
If I recall, this may be the way it operates; bot... Nov 2 2009, 03:16 PM
underthetire
If I recall, this may be the way it operates; bo... Nov 2 2009, 03:38 PM
orange914
Yes. Sort of. Early cars should have the indicato... Nov 2 2009, 07:26 PM
flipb
[quote name='montoya 73 2.0' post='1223878' date=... Nov 2 2009, 09:52 AM
flipb And since I like pictures, here are the two leads ... Nov 2 2009, 10:18 AM
tat2dphreak hmm. I didn't care before, but now I must look... Nov 2 2009, 10:33 AM
plas76targa FWIW - my 72 blinks similar to above - left flashe... Nov 2 2009, 12:25 PM
Phoenix-MN
FWIW - my 72 blinks similar to above - left flash... Nov 2 2009, 12:44 PM
SGB I had the both indicators flashing thing for 15 ye... Nov 2 2009, 03:02 PM
ConeDodger I am glad Andy cleared that up... I thought it was... Nov 2 2009, 03:55 PM
underthetire
I am glad Andy cleared that up... I thought it wa... Nov 2 2009, 04:00 PM
wobbletop Mine both flash at once. Always thought it was the... Nov 2 2009, 03:56 PM
Spoke Mine both flashed on my 71.
Problem was not groun... Nov 2 2009, 04:09 PM
Rod Amazing how many people have this problem!
..... Nov 2 2009, 04:31 PM
kenshapiro2002 I went through all of this about a month ago...che... Nov 2 2009, 06:44 PM
astronomerdave
All exterior lights work properly, but both the d... Nov 8 2009, 02:11 AM
tradisrad
All exterior lights work properly, but both the ... Nov 8 2009, 01:13 PM
underthetire 73, late. independant bulbs. Nov 8 2009, 10:33 AM
tradisrad I swaped out my trun signal relay and they light u... Nov 14 2009, 04:24 PM
kenshapiro2002 One prong.
I swaped out my trun signal relay an... Nov 14 2009, 06:18 PM
Toast Both of mine flash ONLY when I am applying the bra... Nov 14 2009, 07:48 PM
kenshapiro2002 Betting a new flasher relay would cure it...borrow... Nov 14 2009, 09:07 PM
celluloid3 I have the same problem...
Both of mine flash ON... Dec 13 2009, 01:30 AM
Richncherie For the last few days the green left/right turn si... Aug 24 2020, 11:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 04:47 PM |
