> Both turn signal dash lights, flash when the turn signal is used
tradisrad
post Nov 1 2009, 08:44 PM
All exterior lights work properly, but both the dash lights (left and right turn signal) go on when I use my turn signal. I am expecting the left arrow to flash for a left turn and the right arrow for a right turn, but both arrows flash all the time. the car is a 1970. I think I cleaned all the ground points.
Is this a common problem? What is the fix?
thanks
-Rob
jetboy
post Nov 2 2009, 04:46 AM
914 Uber Noob
Let us know if replacing the relay is a fix. Mine do this, but, mine are only intermittent. When doing a walk around, the lights function correctly. Its only annoying to have the "hazard" effect on my gauge.
tradisrad   Both turn signal dash lights   Nov 1 2009, 08:44 PM
flipb   All exterior lights work properly, but both the d...   Nov 1 2009, 08:46 PM
904svo   Make sure all the bulbs are the correct ones, if y...   Nov 1 2009, 09:42 PM
underthetire   I have the same issue with mine. Someone here said...   Nov 1 2009, 10:08 PM
orange914   I have the same issue with mine. Someone here sai...   Nov 1 2009, 11:10 PM
tradisrad   Is it a good thing that I am not alone? Don't ...   Nov 1 2009, 10:13 PM
tat2dphreak   shit, I thought it was the "way it was"....   Nov 1 2009, 11:12 PM
john rogers   Some 914s had but one light in the tach and some h...   Nov 1 2009, 11:27 PM
jetboy   Let us know if replacing the relay is a fix. Mine ...   Nov 2 2009, 04:46 AM
tradisrad   What rust? Well I do have a very small amount in t...   Nov 2 2009, 09:08 AM
rhcb914   I have a 70 and mine has a similar issue. Turn on...   Nov 2 2009, 09:23 AM
type47   If I recall, this may be the way it operates; both...   Nov 2 2009, 09:28 AM
SirAndy   If I recall, this may be the way it operates; bot...   Nov 2 2009, 03:16 PM
underthetire   If I recall, this may be the way it operates; bo...   Nov 2 2009, 03:38 PM
orange914   Yes. Sort of. Early cars should have the indicato...   Nov 2 2009, 07:26 PM
flipb   [quote name='montoya 73 2.0' post='1223878' date=...   Nov 2 2009, 09:52 AM
flipb   And since I like pictures, here are the two leads ...   Nov 2 2009, 10:18 AM
tat2dphreak   hmm. I didn't care before, but now I must look...   Nov 2 2009, 10:33 AM
plas76targa   FWIW - my 72 blinks similar to above - left flashe...   Nov 2 2009, 12:25 PM
Phoenix-MN   FWIW - my 72 blinks similar to above - left flash...   Nov 2 2009, 12:44 PM
SGB   I had the both indicators flashing thing for 15 ye...   Nov 2 2009, 03:02 PM
ConeDodger   I am glad Andy cleared that up... I thought it was...   Nov 2 2009, 03:55 PM
underthetire   I am glad Andy cleared that up... I thought it wa...   Nov 2 2009, 04:00 PM
wobbletop   Mine both flash at once. Always thought it was the...   Nov 2 2009, 03:56 PM
Spoke   Mine both flashed on my 71. Problem was not groun...   Nov 2 2009, 04:09 PM
Rod   Amazing how many people have this problem! .....   Nov 2 2009, 04:31 PM
kenshapiro2002   I went through all of this about a month ago...che...   Nov 2 2009, 06:44 PM
astronomerdave   All exterior lights work properly, but both the d...   Nov 8 2009, 02:11 AM
tradisrad   All exterior lights work properly, but both the ...   Nov 8 2009, 01:13 PM
underthetire   73, late. independant bulbs.   Nov 8 2009, 10:33 AM
tradisrad   I swaped out my trun signal relay and they light u...   Nov 14 2009, 04:24 PM
kenshapiro2002   One prong. I swaped out my trun signal relay an...   Nov 14 2009, 06:18 PM
Toast   Both of mine flash ONLY when I am applying the bra...   Nov 14 2009, 07:48 PM
kenshapiro2002   Betting a new flasher relay would cure it...borrow...   Nov 14 2009, 09:07 PM
celluloid3   I have the same problem... Both of mine flash ON...   Dec 13 2009, 01:30 AM
Richncherie   For the last few days the green left/right turn si...   Aug 24 2020, 11:55 PM
- Lo-Fi Version Time is now: 15th October 2026 - 04:46 PM
