It's official, fuch the /4...... I'm doing a six, I'm nuts, JP wins |
Mark Henry |
Oct 26 2009, 09:56 AM
So.... I got all these cool parts, straight trade, his junk for my junk.
Doesn't matter how I look at this, a big four adds almost 0 value to a 914, stick a six in and it's worth a lot more. Especially here in Canada! I'm actually down sizing from a 2.7 T4 to a 2.0 six (IMG:style_emoticons/default/screwy.gif) I got a 75 911S with 69T 2.0 engine and trans, plus four fuchs. I could break this and make a nice tidy profit, but I don't like to tempt fate. I think it would be bad karma to pass this up. I only have 2 of the four fuchs right now but I'm asured I'll have the other 2 and an extra seized 911 engine. No info other than it's seized. The engine has a lot of cool stuff on it 40IDA webers, a 69S dizzy, permatune and turbo lower covers. The guy also said it has "hot cams" so my fingers are crossed and maybe there's some more goodies in there. It turns over nice, lots of meat on my 215mm flywheel (nice) and the cam lobes look good. I'll be doing a rootworks special and will make most of my own parts. I was hoping to use the '75 5-bolt rear hubs, but I think it's the wrong year. I'll get a set of rears hubs off of Eric. I have everything for a 2.7 nickies T4, I'm glad I haven't put it together because it now going in my bug. Almost like fate man, far out. I have no money, but I have a whack (I had a whole other stroker engine for the bug) of nice T4 stuff that will be in the classifieds real soon. I'll be listing some stuff today (and later this week) here first before the samba! I'll trade for /6 parts (IMG:style_emoticons/default/biggrin.gif) -- Cheers Mark Attached image(s) |
SLITS |
Nov 2 2009, 11:59 AM
Couple of "V" blocks and a dial indicator*** .... set dial at "0" on the base circle and rotate ... gives you total lift on the lobe .... multiply by rocker ratio and you have actual lift at the valve.
Otherwise ... same method with cam in housing and decrease by rocker ratio if measuring at the valve retainer. At least I think it's this simple and how I did it for years. Now, determination of opening and closing and duration is another matter all together. *** If the cam is out of the housing |
J P Stein |
Nov 2 2009, 12:50 PM
Couple of "V" blocks and a dial indicator*** .... set dial at "0" on the base circle and rotate ... gives you total lift on the lobe .... multiply by rocker ratio and you have actual lift at the valve. Otherwise ... same method with cam in housing and decrease by rocker ratio if measuring at the valve retainer. At least I think it's this simple and how I did it for years. Now, determination of opening and closing and duration is another matter all together. *** If the cam is out of the housing I've done that with calipers X 1.5.....quick & dirty if you have a good idea of what the cam should be....but.... with the difference between say Solex & E cams, you can get it wrong without checking lobe centers & duration. |
SLITS |
Nov 2 2009, 01:07 PM
Couple of "V" blocks and a dial indicator*** .... set dial at "0" on the base circle and rotate ... gives you total lift on the lobe .... multiply by rocker ratio and you have actual lift at the valve. Otherwise ... same method with cam in housing and decrease by rocker ratio if measuring at the valve retainer. At least I think it's this simple and how I did it for years. Now, determination of opening and closing and duration is another matter all together. *** If the cam is out of the housing I've done that with calipers X 1.5.....quick & dirty if you have a good idea of what the cam should be....but.... with the difference between say Solex & E cams, you can get it wrong without checking lobe centers & duration. Yes Sir JP, but then you forgot to mention mounting a degree wheel on the crank pulley to get those figures. And do you measure duration at 0.050" or beginning of indicator movement? |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:26 AM |
