> Both turn signal dash lights, flash when the turn signal is used
tradisrad
post Nov 1 2009, 08:44 PM
All exterior lights work properly, but both the dash lights (left and right turn signal) go on when I use my turn signal. I am expecting the left arrow to flash for a left turn and the right arrow for a right turn, but both arrows flash all the time. the car is a 1970. I think I cleaned all the ground points.
Is this a common problem? What is the fix?
thanks
-Rob
type47
post Nov 2 2009, 09:28 AM
Viermeister
If I recall, this may be the way it operates; both turn signal lights in the tach flash no matter what, left or right. I think sometime it change either from both flashing (as someone with an early car stated above) to individual direction flashing or the other way around, individual direction to both flashing.
post Nov 2 2009, 03:16 PM
Resident German
QUOTE(type47 @ Nov 2 2009, 07:28 AM) *
Yes. Sort of. Early cars should have the indicator lights operate separately. Later cars only have one bulb. And then there's the cars in-between that still have both bulbs but they always flash together.
Confused? Welcome to the club ... (IMG:style_emoticons/default/biggrin.gif)
On a '70, they should work individually. Try this, when blinking, rev up the engine above 2k rpm or so and see if the lights blink individually then.
(IMG:style_emoticons/default/popcorn[1].gif) Andy
orange914
post Nov 2 2009, 07:26 PM
http://5starmediaworks.com/index.html
QUOTE(SirAndy @ Nov 2 2009, 01:16 PM) *
about when was the change? we should all state what year model we have and note the type of operation, inquiring minds what to know
i'll start...
early 73', left and right on dash operate seperately
mike
tradisrad   Both turn signal dash lights   Nov 1 2009, 08:44 PM
flipb   All exterior lights work properly, but both the d...   Nov 1 2009, 08:46 PM
904svo   Make sure all the bulbs are the correct ones, if y...   Nov 1 2009, 09:42 PM
underthetire   I have the same issue with mine. Someone here said...   Nov 1 2009, 10:08 PM
orange914   I have the same issue with mine. Someone here sai...   Nov 1 2009, 11:10 PM
tradisrad   Is it a good thing that I am not alone? Don't ...   Nov 1 2009, 10:13 PM
tat2dphreak   shit, I thought it was the "way it was"....   Nov 1 2009, 11:12 PM
john rogers   Some 914s had but one light in the tach and some h...   Nov 1 2009, 11:27 PM
jetboy   Let us know if replacing the relay is a fix. Mine ...   Nov 2 2009, 04:46 AM
tradisrad   What rust? Well I do have a very small amount in t...   Nov 2 2009, 09:08 AM
rhcb914   I have a 70 and mine has a similar issue. Turn on...   Nov 2 2009, 09:23 AM
type47   If I recall, this may be the way it operates; both...   Nov 2 2009, 09:28 AM
SirAndy   If I recall, this may be the way it operates; bot...   Nov 2 2009, 03:16 PM
underthetire   If I recall, this may be the way it operates; bo...   Nov 2 2009, 03:38 PM
orange914   Yes. Sort of. Early cars should have the indicato...   Nov 2 2009, 07:26 PM
flipb   [quote name='montoya 73 2.0' post='1223878' date=...   Nov 2 2009, 09:52 AM
flipb   And since I like pictures, here are the two leads ...   Nov 2 2009, 10:18 AM
tat2dphreak   hmm. I didn't care before, but now I must look...   Nov 2 2009, 10:33 AM
plas76targa   FWIW - my 72 blinks similar to above - left flashe...   Nov 2 2009, 12:25 PM
Phoenix-MN   FWIW - my 72 blinks similar to above - left flash...   Nov 2 2009, 12:44 PM
SGB   I had the both indicators flashing thing for 15 ye...   Nov 2 2009, 03:02 PM
ConeDodger   I am glad Andy cleared that up... I thought it was...   Nov 2 2009, 03:55 PM
underthetire   I am glad Andy cleared that up... I thought it wa...   Nov 2 2009, 04:00 PM
wobbletop   Mine both flash at once. Always thought it was the...   Nov 2 2009, 03:56 PM
Spoke   Mine both flashed on my 71. Problem was not groun...   Nov 2 2009, 04:09 PM
Rod   Amazing how many people have this problem! .....   Nov 2 2009, 04:31 PM
kenshapiro2002   I went through all of this about a month ago...che...   Nov 2 2009, 06:44 PM
astronomerdave   All exterior lights work properly, but both the d...   Nov 8 2009, 02:11 AM
tradisrad   All exterior lights work properly, but both the ...   Nov 8 2009, 01:13 PM
underthetire   73, late. independant bulbs.   Nov 8 2009, 10:33 AM
tradisrad   I swaped out my trun signal relay and they light u...   Nov 14 2009, 04:24 PM
kenshapiro2002   One prong. I swaped out my trun signal relay an...   Nov 14 2009, 06:18 PM
Toast   Both of mine flash ONLY when I am applying the bra...   Nov 14 2009, 07:48 PM
kenshapiro2002   Betting a new flasher relay would cure it...borrow...   Nov 14 2009, 09:07 PM
celluloid3   I have the same problem... Both of mine flash ON...   Dec 13 2009, 01:30 AM
Richncherie   For the last few days the green left/right turn si...   Aug 24 2020, 11:55 PM
- Lo-Fi Version Time is now: 15th October 2026 - 04:47 PM
