> three unknown wires under passenger seat, actually 6 wires into 3 plugs
steveherman
post Nov 2 2009, 05:27 PM
what are they for?
where do they go?
(IMG:http://i193.photobucket.com/albums/z135/fast2000hayabusa/IMG00006-20091102-1724.jpg)
SLITS
post Nov 2 2009, 10:11 PM
"This Utah shit is HARSH!"
In your image, it appears that the big yellow wire has a split connector on it. If the two yellow wires that run to the interlock relay are joined, your seatbelt interlok is diabled and it won't make any difference if you hook up the stock sytem.
Image needs to be brighter to see the connectors. I know the two wire connector on the left is a plug for the sensor from the seat pad. The one you have circled in red.
steveherman   three unknown wires under passenger seat   Nov 2 2009, 05:27 PM
underthetire   Seat cushion for seat belt warning ??   Nov 2 2009, 06:00 PM
steveherman   Seat cushion for seat belt warning ?? maybe one ...   Nov 2 2009, 06:17 PM
Rod   There were various things under the seat which are...   Nov 2 2009, 06:37 PM
steveherman   but i am putting things back in. and i dont know w...   Nov 2 2009, 06:56 PM
zx-niner   Is it a 1974 model with the seatbelt ignition inte...   Nov 2 2009, 09:10 PM
steveherman   yes it is a 74 with interlock system. i am putting...   Nov 2 2009, 09:44 PM
steveherman   these are what I am trying to figure out... http...   Nov 2 2009, 10:06 PM
SLITS   In your image, it appears that the big yellow wire...   Nov 2 2009, 10:11 PM
steveherman   In your image, it appears that the big yellow wir...   Nov 2 2009, 11:19 PM
SLITS   Male connector from seat cushion sensor ... it...   Nov 3 2009, 12:17 AM
steveherman   Male connector from seat cushion sensor ... it...   Nov 3 2009, 12:44 AM
Cire   Male connector from seat cushion sensor ... it...   Nov 3 2009, 08:21 AM
Socalandy   Brown is Earth or ground in all 914's and Germ...   Nov 3 2009, 12:43 AM
jt914-6   Look at post #6. There is a male spade connector, ...   Nov 3 2009, 07:05 AM
steveherman   Look at post #6. There is a male spade connector,...   Nov 3 2009, 07:51 AM
jt914-6   Is there a place on the interlock relay to connect...   Nov 3 2009, 08:01 AM
jt914-6   On my '74 I removed the seat belt interlock re...   Nov 3 2009, 08:37 AM
detoxcowboy   O.k> looks like the wires yur circling plug int...   Nov 3 2009, 08:57 AM
- Lo-Fi Version Time is now: 16th July 2025 - 04:02 PM
