oil leak around head and case do I use gaskets or not |
wayne1234 |
Nov 6 2009, 01:04 AM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
Ok I did a search and got mixed reviews... decided while the engine was out for the hell hole repair which is finished I would take car of the oil leaks.. a Little back ground is that I CAN NOT trust what the PO.did. He said the engine was just rebuilt it is a 2.0 with 1.7 heads. there was a firly large leak at the push rod tubes where the seals were cut by a rough opening in the push tube holes in the head .. I got that all cleaned up with a brake hone and it is silky smooth, but it looks like thert is a slight leak at the jugs to the case and maybe at the head , but its hard to tell since ther was oil everywhere. should there be head and base gaskets or not? if there arent any now and it is leaking is it from improper torque? I'm going to pull the heads to take a look any ways but I"m wondering Should I use base and head gaskets or not? if nothing is ther a "dressing " I should use ... This is my first time tearing into a type 4 , but not my first engine Thansk for the imnput
jaxdream |
Nov 6 2009, 09:41 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
W W J D ?????
( what would jake do ) Jaxdream |
Lo-Fi Version | Time is now: 10th June 2024 - 09:41 AM |
