914 Gauge Set-ups - OE Standard & Options, ...OK let's try this again |
Tom_T |
Nov 7 2009, 10:38 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Okay - first of all, this is a question about ORIGINAL Gauge setups for standard factory equipment, factory options, & special order factory/dealer options whith respect to the 1973 MY 914-2.0.
While past suggestions for swap-outs & temporary/removable installations in a "to remain anonymous post here" (IMG:style_emoticons/default/dry.gif) - that's not really what I'm asking about, but Thanx to those of you who had contributed there. Second - some background on my early-73 914-2.0 (then marketed as the "914S" as shown in the 1972 Porsche+Audi docs below), VIN...1954 & GA000424, built 9/72 & first sold/registered 11/72 in CA. I bought the car 3 yrs. or "37 months old" in 12/75, & was told by PO that they were OO - so I'd be 2nd owner with the car since 12/75 continuously. When I got it in 75 the Appearance Group Center Console/Gauges, Fog-lights/dash switch & 5 Fuchs 2L alloy wheels were not on the car. The PO or dealer had removed these items, & IIRC the PO wanted the extra leg-room for hauling around 2 kids (i.e.: 2+1 in the old pre-mandatory-seatbelt days). It also came with the standard fuel/brake combo gauge - as opposed to the fuel/oil temp. combo gauge provided on non-center console cars (because OT was in the console). Beyond finding all of the appropriate attachment holes/clips & electrical connections with evidence of prior use/attachment - I've done extensive research to confirm to my satisfaction that Porsche+Audi sold ALL 914-2.0's "fully loaded" with the Appearance & Performance Groups' options in that 73 MY (at least in the first 1/3 during 1972), although that changed definitely by the 74 MY with everything then becoming extra cost options (except LE set-ups), and possibly P+A had started that extra charge program in Spring 73 (according to Steve Gaglione). I'll be restoring my 914 2L back to original fitment, with a few exceptions for better durability/driving (e.g.: SS HEs, 19mm MC, factory Passenger Side Mirror, etc.), since I want to drive it some, as well as probably doing some concours restoration shows (at least until it gets too dirty (IMG:style_emoticons/default/biggrin.gif) ). I've gone out & bought a restorable console & gauges (I still need a proper early "Kinsle" sp? clock though! (IMG:style_emoticons/default/smile.gif) ), as well as a set of 5 restorable Fuchs wheels, & fog-lights with horns (horns busted in 5/85 accident) & fog-light switch (amber bezel - which I hope was right, since the replacement 1973 owners manual I bought from PP, references a "Green" bezel (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/huh.gif) ). However, I think/hope that I have some latitude in how I configure the dash-pod & center console gauges, in as much as there may have been any options, etc. available at the time? Even at that, the Porsche+Audi ad & sales brochure below seems confused on the issue, as one states that the center console has the oil pressure gauge, while the other says oil temperature (as most generally found in them)..... To the Questions at Hand: 1. Were there any factory options &/or dealer requested options at the time for substitute gauges at either the console &/or fuel combo gauge? I'm pretty sure that VDO at the time also produced Oil Pressure Gauges in the center console size (2-3/8" diam. +/-) &/or in the fuel/OT combo gauge insert size (same since OP insert was used in the 911s IRRC). > but could either/both be special ordered by a buyer either in the initial build &/or as a dealer change-out later?? (IMG:style_emoticons/default/confused24.gif) ...i.e.: You end up with either a combo fuel/OT (using the non-console type gauge & a clock/OP/voltmeter in the console, or with a combo fuel/OP & the standard clock/OT/voltmeter in the console. 2. Where there any factory special order &/or dealer ordered optional Cylinder Head Temp. Gauges available for the 914s at the time? ...if so, what were they (size/markings/face style) & where/how were they mounted "back in the day"?? (IMG:style_emoticons/default/confused24.gif) 3. Is it acceptable from Originality terms & in concours events (restoration in my case) to add any of those, if they were indeed available at the time - even though they were probably not in my particular car originally?? (IMG:style_emoticons/default/confused24.gif) I would like to have had that extra instrumentation back in the day myself (having intended to add back at least the console even back then), and would certainly appreciate it today to protect my 37 yr. old 914 from mechanical problems whenever I do drive it. The only question in my mind is how to do it in a way that was both available & appropriate in the original period? FYI - following are some pix of both my 914's instruments & my research on consoles, the console/gauges I got, etc. DEC. 1972 MAGAZINE - PORSCHE+AUDI "914S" ADVERT DENOTING "INCLUDED" EXTRAS - NOTE THAT THIS SAYS OIL PRESSURE GAUGE: . FALL 1972 PORSCHE+AUDI EARLY "914S" SALES BROCHURE PAGE ON "INCLUDED" OPTIONS - NOTE THAT THIS SAYS OIL TEMP GAUGE: . CORRECT 1973 MY CENTER CONSOLE FROM P914 WEBSITE - NOTE CORRECT "KINSLE" CLOCK (NON-QUARTZ), OT GAUGE WITH WIDE RED BAND, & VOLTMETER: . OE CENTER CONSOLE & GAUGES FROM VIN4732901102 - JUST 892 CARS BEFORE MINE 7 ALSO A 9/72 BUILD: . OE COMBO FUEL / OT GAUGE (WIDE RED BAND) AS USED IN 1973 MY NON-CENTER CONSOLE 914s: . ...continued.... |
1970 Neun vierzehn |
Nov 7 2009, 11:42 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Tom,
If no fog light switch, what is there? A hole, or just the vinyl between the headlight switch and the warning flasher? Is there evidence under the dash and/or on the carpet that a center console has indeed been removed? Since your 1973 appears to have been produced on or near the cusp of 72/73 MY change over, could perhaps the factory made your car without those items? The missing fog lights are puzzling though. I'll assume the car just had the grilles only? As far as retrofitting an OEM console with gauges, I am of the opinion that it is entirely suitable to add the correct gauges that are appropriate to your engine (2.0) and trim level. The fact that your e-brake/fuel level gauge does not have a engine temp gauge in it would lead me to believe that the center console would be a viable addition to your car. I find it curious to see a dealer remove gauges, console and fog light hardware. The missing wheels are a comonplace fact of life for 914s. Between dealer efforts in marketing and increasing profitability, you can add customer preferences for different OEM wheels or some aftermarket rims as the plausible explanation for the missing Fuchs. Paul |
Tom_T |
Nov 8 2009, 12:43 AM
Tom, If no fog light switch, what is there? A hole, or just the vinyl between the headlight switch and the warning flasher? Is there evidence under the dash and/or on the carpet that a center console has indeed been removed? Since your 1973 appears to have been produced on or near the cusp of 72/73 MY change over, could perhaps the factory made your car without those items? The missing fog lights are puzzling though. I'll assume the car just had the grilles only? As far as retrofitting an OEM console with gauges, I am of the opinion that it is entirely suitable to add the correct gauges that are appropriate to your engine (2.0) and trim level. The fact that your e-brake/fuel level gauge does not have a engine temp gauge in it would lead me to believe that the center console would be a viable addition to your car. I find it curious to see a dealer remove gauges, console and fog light hardware. The missing wheels are a comonplace fact of life for 914s. Between dealer efforts in marketing and increasing profitability, you can add customer preferences for different OEM wheels or some aftermarket rims as the plausible explanation for the missing Fuchs. Paul Thanx Paul - you're up late back there, so it's esp. appreciated! (IMG:style_emoticons/default/smile.gif) Yes - there was a perfect hole in dash (see pic below) & the wiring connectors show evidence of prior connection (scratches/wear on metal). It had plain chrome grills on when I got it, & when I disassembled the front bumper for my pre-repairs/restoration assessment (these pix), I found the fog light wires cut-off behind each horn L&R (see pic of one side below). When I did the assessment & pix - the center console area had similar evidence it was there, including "used" wiring connectors, attachment bracket bolt/screw holes with wear &/or speed-nut or clip connectors still in place, etc. (pix not included here, self-explanatory) - as well as the Fuel/Brake Warning Light combo gauge used with the console equipped models, as you noted. I further had done the research in at least 20+ period sources from both P+A window stickers, ads & marketing brochures, & in various period auto magazines (both ads & articles/road-tests) - all of which stated that the Fuchs, fog lights & console were all included in 73 MY 2L models (since I don't have any window sticker nor other dealer docs from mine). As to why - a dealer could've wanted either or both of them for another 914 at an up-charge for no cost to the dealer, as with the notorious Fuchs wheels trick. It could've also been the PO removed the console for leg room, or had the dealer/shop do it for them. Likewise, the fog lights could've been left off by PO choice - or a body shop short-cut or "funny business" - that took off the fog lights when it was repainted from L80E to the Tan/Gold when I got it. Hard to say at this point, & I was young & naive when I bought it & failed to get the full story, all the car's docs (including owners manual), the parts & components & wheels - if they even still had them then. I've researched the correct gauges & have the proper OT with the wide red band & voltmeter (all the same) & both were mfgd. during the 73 MY run, although after my 914's specific 9/72 mfgr. date. What I'm asking here is: 1. Whether there were optional additional gauges available at that time as either a special order from the factory, or from the dealer as a "genuine Porsche" upgrade? 2. Whether I can now add any which were available then as an acceptable originality example, as it could've been upgraded by a buyer upon order from the factory &/or as added optional equipment from the selling dealer? ...as I would've done had I had any spare coin in those younger & leaner years! (IMG:style_emoticons/default/biggrin.gif) CLEAN HOLE IN MY DASH FROM WHERE THE FOG LIGHT SWITCH "MYSTERIOUSLY DISAPPEARED" - E-FLASHER IS ACTUALLY ONE OVER IN THE FOG LIGHT SWITCH POSITION IIRC: . CUT FOG LIGHT WIRES AT FOG LIGHT/HORN WIRING HARNESS FROM BEHIND HORN: . |
Lo-Fi Version | Time is now: 1st June 2024 - 05:08 AM |
