Looking for 6 conversion info, The wife gave me the green light |
jmill |
Nov 10 2009, 09:35 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Out of the blue the wife gave me permission to spend a bunch of cash on the teener. I have the slightest idea what I did right or what she did wrong.
I have to check out the finances but I'd like to do a 6 conversion. I know diddly about the flat 6. I need some help. My end goal is to basically have a street legal track car. I like the small high reving 6's but like I said I know nadda. The only thing that it has to have is carbs. I'm not into FI and ECU's. What's my best engine choice? I'm about 1/4 way through the 911 performance handbook trying to educate myself. I can build an engine if thats my best option. I should also ask the average conversion cost. (IMG:style_emoticons/default/blink.gif) |
ClayPerrine |
Nov 11 2009, 09:37 PM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Here is what I would do if I were going to build a small motor..
Start with a sand cast aluminum case (68 or older). Get a 2.2S crank and rods. 2.7S pistons and cylinders. 2.7 S heads drilled for twin plug. Turbo oil pump. Do all the recommended case mods. 906 cams. MFI with either high butterfly or slide valve stacks. Twin plug distributor. It would look something like this...... What you get is a 2.5 short stroke screamer that wont pull down low, but will really come on strong when you get it on the cams..... |
Mark Henry |
Nov 14 2009, 06:47 AM
Here is what I would do if I were going to build a small motor.. Start with a sand cast aluminum case (68 or older). Get a 2.2S crank and rods. 2.7S pistons and cylinders. 2.7 S heads drilled for twin plug. Turbo oil pump. Do all the recommended case mods. 906 cams. MFI with either high butterfly or slide valve stacks. Twin plug distributor. It would look something like this...... What you get is a 2.5 short stroke screamer that wont pull down low, but will really come on strong when you get it on the cams..... How about with webers till I get a MS twin plug system set up..... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:02 PM |
